Bluetooth radio not remembering pairing
This section is for General Enquiries or for Systems not Covered Above
Peter Palmer
x 12
Unread post by Peter Palmer »
I've asked this question on the Berlingo forum (even though we have a dispatch) but didn't get any replies so I'll give it a go here. We have a 2015 Dispatch van, the enterprise model and the factory radio won't remember the bluetooth pairing with our phones all of a sudden, it used to work fine although it was still a bit of a faf with two separate phones linked to it but all of a sudden you need to enter the paring code every time you want to connect your phone either to make a call or play music. It still remembers the radio presets though so its not as if its losing power, when you go into the bluetooth menu it just says no phones are paired where as previously it even had the details of the previous owners phones.
We even had the battery off the other week for a few hours as we needed it to start another car so that would have done a re-set I presume if one was required.
admiral51
(Donor 2026)
x 391
Re: Bluetooth radio not remembering pairing
Unread post by admiral51 »
Just thinking aloud but is the head unit software up to date and or have the phones been updated with software, it could be an issue with one or both running on incompatable software ?
x 6955
I suspect this is a problem with the hands free unit if fitted. Pop your VIN up and I'll see what system you have fitted.
Peter Palmer
x 12
I know this is an old topic but putting my VIN in another topic suddenly reminded me of this one.
VIN is VF7**************[VIN obfuscated, can be read by forum staff]
We are still having the same problem, pairs absolutely fine but once the engine has been switched off it doesn't remember the pairing.
x 6955
Ok, so no Fiat units on this van, which if there were I would suggest a known issue with the bluetooth modules.
There is a technical document concerning this issue, but I don't have the contents unfortunately as there's a small charge for access. So I can't at this stage tell you what it is or what the fix is.
Peter Palmer
x 12
Ok thanks, how do I get hold of that document then, main dealer? Is it radio related as I could get another head unit, I do have diagbox/lexia available.
x 6955
Hi Peter, I've sent you a PM
Peter Palmer
x 12
Thanks, I've read the PM, I've just done a quick scan with diagbox and it says there aren't any faults stored for the radio. When it does a global scan and lists all the modules like the BSI etc. it shows the radio/radiotelephone as present but the "handsfree" is showing as not installed. I take it it doesn't need the handsfree bit because the radio is a self contained bluetooth one?
I have also ripped out the traffic master system whilst I had the dash panels off (replacing gear linkage) I was sick of hearing "satellites are back in view". It was surprisingly easy to do, the only wires connected to the car were a blue and red wire hacked into the loom and a brown ground wire, everything else went to the various traffic master bits (GPS aerial, microphone, speaker, and phone USB plug).
I'll let you know about the PM in due course.
Thanks again.
x 6955
So you do have the RD45 system which has integrated Bluetooth, but you also have a telephone interface unit. This may be for emergency calls / assistance - so check if you have an SOS or Services button somewhere - if you do that telephone interface will be for that. But as far as Bluetooth goes, this module is integrated into the RD45.
Mission1979
Unread post by Mission1979 »
GiveMeABreak wrote: 21 Jun 2021, 23:29 So you do have the RD45 system which has integrated Bluetooth, but you also have a telephone interface unit. This may be for emergency calls / assistance - so check if you have an SOS or Services button somewhere - if you do that telephone interface will be for that. But as far as Bluetooth goes, this module is integrated into the RD45.
Sorry to jump onto this thread but we are having this exact same issue with our 2016 C3. Worked perfectly for the first two years we had it and has recently just developed amnesia. Same issue, pairs perfectly fine then instantly forgets once the ignition is switched off. Any guidance would be appreciated.
Vin number is VF7**************[VIN obfuscated, can be read by forum staff].
Thankyou for any help.
Tim
x 6955
You've made a mistake in your VIN, Tim, missing one alpha / digit somewhere.
Mission1979
GiveMeABreak wrote: 18 Feb 2023, 21:12 You've made a mistake in your VIN, Tim, missing one alpha / digit somewhere.
Oops sorry
Had been hidden behind an old parking ticket so it's a bit sticky
x 6955
Ok, so just checked you have RD45, so possible reasons can also be recent phone software updates. These updates can put new Bluetooth updates on your phone that can cause some compatibility features. I suggest you first check to see if your phone has a later software version that may correct any bugs.
Then completely remove the phone from the C3's system - that is delete it completely and do the same for the Citroen Bluetooth connection on your phone.
Switch the ignition off and leave the car for 15 minutes or so, then try and re-pair the phone again creating a new Bluetooth connection and adding the phone as a completely new device ( as there shouldn't be any previous phones remaining after the last steps).
Mission1979
GiveMeABreak wrote: 19 Feb 2023, 13:57 Ok, so just checked you have RD45, so possible reasons can also be recent phone software updates. These updates can put new Bluetooth updates on your phone that can cause some compatibility features. I suggest you first check to see if your phone has a later software version that may correct any bugs.
Hi there Marc
Done all that but it just forgets the mobile connected immediately after turning off the ignition.
My phone remembers the connection but there are no phones stored in the head unit.
Tim
x 6955
Ok, so there is something that may help determine if it is the unit that needs replacing or the or the software that needs updating.
You can identify the software version of the RD45 by reading the by performing the following operation:
  • Start the engine
  • Switch on the RD45 car radio
  • Simultaneously press buttons 2, 4 and 6 for 3 seconds Press the "SOURCE" button for 3 seconds:
  • 'Program display' should be displayed.
  • Press the "SOURCE" button again for 3 seconds: 'Display of the software version' or similar should be shown.
write down the software version of the RD45 car radio Switch off the ignition.
You are looking for something like one of these.
VO 32060
41100
43030
Let me know what you have.
