Lidl and Aldi Car accessories
x 8437
Re: Lidl and Aldi Car accessories
myglaren wrote: 13 Feb 2023, 10:38
Gibbo2286 wrote: 13 Feb 2023, 10:21 Last week in Lidl Monmouth they had a woodworking lathe, I was tempted but then thought nah! :)
They had one here too.
I bought a broom, it was cheaper.
Just think Steve, had you bought the lathe you could have then made all your own broom handles ;)
And the wooden part of the head too...
x 5679
I have a lathe here. Belongs to #1 son, also a load of other machinery that takes up half a room.
I don't think that the council would be best pleased at me cutting their trees down to reduce to janitorial implements.
x 8437
myglaren wrote: 13 Feb 2023, 18:17 I don't think that the council would be best pleased at me cutting their trees down to reduce to janitorial implements.
No, maybe not but Trigger would be proud of you :)
x 3298
Next Sunday Lidl have a few car related items (including an inspection camera system);
https://www.lidl.co.uk/c/car-care/c2651/w2
x 5679
Went to a different Lidl yesterday. Lathe but no slide copier :(
x 6950
I doubt those 4 non-rechargeable batteries would give much operation time, I wonder if that's why if the operating time was omitted...
x 3298
On Thursday (23/02) Aldi have a few vehicle related items for sale (buried in a load of tools);
https://www.aldi.co.uk/auto-xs-gps-vehi ... 3578247000
x 3298
Next Sunday (05/03) Lidl are doing a load of DIY stuff, including a plasma cutter and a wire welder;
https://www.lidl.co.uk/c/diy-heroes/c2663/w2
x 5679
The slide/negative scanners were in today but look as though they only work with Windows/Macs.
Although if they work with a Mac they 'should' work with Linux.
Postponed purchase
Looks as thought Vuescan might work.
x 3298
For the cyclists among us (Jim?) Lidl have a few cycle related items;
https://www.lidl.co.uk/c/cycle-club/c2667/w2
x 3298
This is not from Lidl or Aldi, but it could be a useful thing to buy (especially if the weather gets a bit too warm for comfort). I have got one of these, and my Mum reckons the one I gave her a few years ago was literally a life saver (as she has a heart condition), as it turned bad night (with no sleep) into tolerable ones (with some hours sleep).
https://www.bmstores.co.uk/products/bla ... ube-368417
x 1947
If that's an air cooler then where does the hot air from the heat exchanger go?
x 8161
From what it says I would think it uses a couple of ice blocks which you have to freeze first and then place in the cube and it passes the room air over them using the heat in the air to melt the ice pack and thus have a cooled exhaust. So it is a latent to kinetic converter rather than an exchanger!! Just my thoughts :)
x 3298
You can fill the removeable tanks to the red lines (but not above it), put them in the freezer until the water freezes, pop the caps back on, and then put them in the unit. However, even if you don't freeze the water they do take a couple of degrees of the temperature of the air that passes through the unit.
There is a water trough at the bottom of the unit that the tanks keep topped up. There is a 'filter' that then sits in this trough, wicking up the water (and providing a large surface area). As the water evaporates it cools the air down slightly, and the fan blows this cooled air out.
x 1947
Haha, you both did something I should have done. Actually read all the details!
