Hey, so ive just cleaned my 1.6 hdi egr valve, and the car has really rough idle. It also cant maintain the idle, after a little while it stalls. Also when revving the engine the rpm goes up really slow, and in regular intervals the throttle feels like it cuts off, if you get what i mean. I have no check engine light on, no issues like that.
308 1.6 hdi rough idle, revving
- x 6948
Re: 308 1.6 hdi rough idle, revving
A full diagnostic is really needed to be honest as there can be many reasons for this sort of behaviour including fuelling / blocked air inlet manifold etc.
Put any codes you have with you VIN here and we can may be able to provide some pointers for you.
Andreasson
I had the following fault codes
P1462
P1351
P0192
P0490
P1459
P0409
Vin VF3**************[VIN obfuscated, can be read by forum staff]
P1462
P1351
P0192
P0490
P1459
P0409
Andreasson
Also when i try and run it, it produces a ton of whiteish smoke
Andreasson
Kinda like one of the intake or exhaust valves were stuck, and there was no compreasion
Andreasson
Anyone anything?
moizeau
- x 423
Stick your VIN up so the codes can be confirmed.
My 1.6 HDI threw similar codes but is the 16V 90 BHP
P0409, P1459, P0490 all relate to the EGR. Are you checking it with a diagnostic tool that can do actuator tests? Just because it's clean doesn't mean it moves. You should hear a ticking when the engine is turned off. This is the self clean cycle. Mine was dead on the mechanical side and the electrical side. Also it could be the wiring that feeds it. The white smoke, does it smell of diesel? Does it clear a bit when warm? What happens if you run it without the MAF plugged in?
Pete
- x 6948
Leave it with me (we already have your VIN and the codes in your previous post above) and I'll pop something up shortly. I've been busy on other posts, so can't always get round to everyone with available time...
- x 6948
So looking at the fault descriptors, the main culprit would appear to be your EGR Valve being coked up with carbon, so would recommend that this is replaced or removed and cleaned up.
You can ignore the P1351 Pre-heating relay circuit: Coherence; Relay supplied and glow plugs not supplied (this is a common fault but means your glow plugs need replacing at some point.
| Fault Code: | P1462 |
| Description of Fault: | Electric EGR valve position copy signal: Difference between the stops programmed at short term. Drift of more than 8% of the position of the EGR valve at the lower stop in relation to that learned during the programming at the very first powerlatch (between the key switch-off and the switching of the ECU to dormant mode). Fault is active under the following conditions:
| Conditions for Fault to clear: | 5 starts with driving. |
| Downgrade Modes whilst Fault is active: | - |
| Symptoms: |
| Suspect Areas: |
| Fault Code: | P0192 |
| Description of Fault: | Fuel pressure signal : Short circuit to earth. The fault occurs if the voltage of the fuel pressure signal is less than the minimum threshold of 0.2 V for 40 milliseconds or 2 engine revs. |
| Conditions for Fault to clear: | Ignition on |
| Symptoms: |
| Suspect Areas: |
| Fault Code: | P0490 |
| Description of Fault: | Position indicator signal of the EGR valve : Positive loop gap. Positive difference of 30% % between the exhaust gas recirculation valve position reference value and the position measured (For 10 seconds). |
| Conditions for Fault to clear: | Driving for 5 minutes |
| Symptoms: |
| Suspect Areas: |
| Fault Code: | P1459 |
| Description of Fault: | Position indicator signal of the EGR valve : Valve jammed open while driving. EGR valve jammed shut while driving for 5 seconds Cleaning forced by the engine ECU |
| Symptoms: |
| Suspect Areas: |
| Fault Code: | P0409 |
| Description of Fault: | Electric EGR valve position copy signal : Valve sticking during the initialisation. Valve sticking for 8 seconds during the initialisation of the powerlatch (between switch off using the key and the ECU going to sleep). The following conditions have to be met: - The engine coolant temperature should be between 10 and 100 ° C - The battery voltage has to be between 10 and 15 volts |
| Downgrade Modes whilst Fault is active: | |
| Symptoms: |
| Suspect Areas: |
