2012 CITROEN DS5 COURTESY & SUN VISORS LAMP NOT WORKING
Edson Achaca
Unread post by Edson Achaca »
Good day!
I have a 2012 Citroen DS5 (Diesel) and suddenly the Ambiance lamps, the map reading lamps and the sun visors lamps stopped working.
I have attached the picture of what lights I’m talking about.
x 6946
Re: 2012 CITROEN DS5 COURTESY & SUN VISORS LAMP NOT WORKING
Try fuse F16 and F17 in the BSI
Edson Achaca
Thanks I’ll check and the seat heater is not working also what fuse must it be? Because it also suddenly stoped working.
x 6946
If only one heated seat is not working, then it won't be the fuse as the same fuse operates both driver and passenger heated seats.
If this is the case it is likely the heated seat pad(s) are faulty.
If none of the front seats are working then the fuse is F9 located in the BFH3 fusebox on the left hand side shown here:
Edson Achaca
Yes both seat heaters are not working I’ll check the fuse you said.
