Does anyone know if the C5 X7 outer CV joints are a one fits all, as I've found one for sale & they list all the models it fits 2008 2.0 -3.0ltr but doesn't list the 2.7
https://www.ebay.co.uk/sch/i.html?_from ... 5&_sacat=0
CV joints
- x 1490
Re: CV joints
Some X7s are fitted with shafts that do not have removable CVs - but I don't think it's engine specific, just depends on what was on the shelf on the day!
Kenmac15
- x 4
Re: CV joints
Yep & just my poxy luck I've got the one that won't splitRichardW wrote: 12 Jan 2023, 12:26 Some X7s are fitted with shafts that do not have removable CVs - but I don't think it's engine specific, just depends on what was on the shelf on the day!
Ken
“I have not failed. I've just found 10,000 ways that won't work.”
Kenmac15
- x 4
Re: CV joints
Well an update on the CV joint.RichardW wrote: 12 Jan 2023, 12:26 Some X7s are fitted with shafts that do not have removable CVs - but I don't think it's engine specific, just depends on what was on the shelf on the day!
Richard was 100% correct about some not splitting as mine wouldn't split but I did learn something. Just to see how the joint was held on I took a cutting blade to the joint & cut it in half & the bearing race seems to pressed on the shaft but after I got the joint off the end of the shaft it had the C clip channel groove, so I bought a new joint which came with a new C clip & the joint fits perfect so turned out a £30 job instead of £150+ so over the moon.
Ken
- x 8408
Re: CV joints
ResultKenmac15 wrote: 18 Jan 2023, 21:25Well an update on the CV joint.RichardW wrote: 12 Jan 2023, 12:26 Some X7s are fitted with shafts that do not have removable CVs - but I don't think it's engine specific, just depends on what was on the shelf on the day!
