Fault Code P0949 and B1003
Zee
Unread post by Zee »
Hi all. I have these fault code on my car. P0949 is to do with transmission. Is there anyone that can help me fix it?
Also I have B1003
DS5 hybrid 2012. Brought the car last week just want the codes cleared and faultless.
Oh and P0487. Air mixture problem. EML comes on few times while driving
x 6945
Re: Fault Code P0949 and B1003
Pop the VIN up so the codes can be related specifically to the vehicles engine ECU (please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff).
Zee
Hi
The VIN Number is : VF7**************[VIN obfuscated, can be read by forum staff]
Zee
Hi Marc.
Any luck regarding info on my vehicle VIN?
x 6945
I can't help you with B1003 as there are 2 digits missing from the end. This is a data / systems / communications generic fault that can appear in may systems of the vehicle, so needs the last 2 digits to tie it down to the specific system.
As for p0949:
Fault Code: P0949
Description of Fault: Clutch programming incomplete or not carried out fault: Not characterised. Detection that the bite point has not been programmed.
The time of appearance of the fault code is 1s.
Context of appearance of the fault code: The following conditions have to be met:
  • - ECU woken up
  • -Ignition on for at least 5 secs
Conditions for Fault to clear: -
Downgrade Modes whilst Fault is active: Controlled manual gearbox ECU re-initialises the bite point
Symptoms: Lack of power
Suspect Areas: Controlled manual gearbox ECU
So the first question is have you had any work done on the clutch lately?
Zee
Hi Marc
Thanks for your reply. No I have not had any work done as I just brought the car 2 weeks ago. Just a normal service, bearings and brake pads. Gear seemed to over rev when I set off from traffic lights.
x 6945
What about the history on it? These piloted manual gearboxes can be a nightmare, a manual or automatic box is preferable.
If the clutch has had any work done on it like a replacement, then the clutch bite point must be programmed which requires dealer level diagnostic tools. The ECU is saying there is a programming fault or it has been started and not completed.
If you have any sort of warranty, take it back now is my advice or this could end up being costly.
Zee
Sorry no history. But I can contact the buyer I brought the car off. It was a private seller I'm afraid
Zee
Marc, can it be fixed with a diagbox diagnostic?
x 6945
Diagbox should have the guided procedure contained within it if you have a Lexia VCI kit.
I would look either in the repair section, or run a global test and when complete, look for the piloted gearbox ECU from the list, select this and within the following menus there should be a procedure there for this operation.
Zee
Hi Marc. Thank you! I spoke to the guy who sold the car to me. He had not got any work done on the gearbox. But I know he has been playing about with the car with his snap on machine. Could that be the problem?
x 6945
Very likely!
Entering any procedure before cancelling correctly or exiting the application correctly can leave the ECU in an unconfigured state. This can then lead to the sort of faults you are getting.
