C4 coupe cables under centre console ???
Brown
Unread post by Brown »
Hello.
Can someone tell me what these are & if i should be worried that they're not connected to anything 🤔
2 cables found under centre console near aouto gear knob, don't know where other ends are they seem to disappear of into the harness somewhere
(2008 c4 coupe 1.6 hdi vtr+)
x 6945
Re: C4 coupe cables under centre console ???
First thing is to look at the sleeving of the wires. There will be a sequence repeated every 5-6" or so. Let me have the codes and I may be able to give some pointers.
Brown
SIODIC 90916783 AWG 28-24 NISSEI
Thick one looks something like that nbut cant get codes off other wires not without un latting em
Brown
This is where they join into harness & seem to carry on & go up back of heater control/stereo
x 6945
I can't help with the large one, but if you look at the thinner wires, the code numbers are easily visible for example where I have arrowed in red in your picture - just look for similar on the ones you are holding. Unfortunately the wiring colours are useless as PSA don't go by the wire colour (they use anything going) only the code.
citroenguy
(Donor 2021)
x 77
Unread post by citroenguy »
Looks like some kind of stereo wiring, USB/aux or similar
I have various repair handbooks and wiring diagrams for C5 mk1, Xantia, XM, Berlingo and C3 mk1.
I have Lexia/Diagbox (Sweden) and Servicebox/sedre
Brown
(Looks like some kind of stereo wiring, USB/aux or similar)
That's my thinking looking at where other ends are heading .
As for wire codes I'll have to have another look i tried but couldn't make em out, half the letters or numbers were all smudged & didn't fancy un tangling em any more than were already & risk breaking something
x 1055
Unread post by wheeler »
Do you have a pic of the pins of the connector face on? looks like the wiring is in a sheath/flex so you wont likely get any meaningful codes off it. I agree it looks like some sort of Aux/ USB lead but cant recall there ever being anything like that at the centre console on that age of C4. Could it be aftermarket? do you still have the original stereo?
Brown
Yes still original stereo nothing after market.
No pics face on only from side
Can take some next time I take out centre console & post on here if it helps
Loonyman74
Unread post by Loonyman74 »
That's for usb
