Stickyfinger wrote: 30 Nov 2022, 08:55 It has so much wax on its undersides I think it needs Brazilian numberplates![]()
- x 8397
Re: I am an Activaist-v6 and a 2.1Estateerr
- x 1996
Oooops its German !
Needs a compound for sure ! Ok, lets see what else there is to do on the body Inside is great, original radio has been stolen but everything else is there
- x 8397
Traitor...
I've booked the scrap man for you... He'll come and collect it in the morning
- x 1996
Says the man with a PissPan Pisso on his drive
- x 8397
It's bouncier than Tigger on speed... I'm sure they forgot to install suspension when it was made and accidentally put in a wooden steering system...
- x 3565
I've fixed one issue already for you, Sticky. Surprisingly easy to do the conversion on these
- x 1996
Gosh, where did you find the parts ?
- x 1996
Nothing going wrong with the Activa or the AX (AX is my winter car), XM awaits garage space and the Pluriel is under a cover to the side of next doors stables.....so
I have now started the cleaning and inspection of the undersides of the "8k Barn" Golf after a Christmas break.
Front wheel arches and brakes/boots/ball joints first.
Initial cleaning reveals this so far, the runs and black patches are factory underseal, brake disks are as fitted as are the pads. All rubber boots and joint covers seem soft and compliant. I will next remove the arch liner and have a look under there.
I think the wheel bolts tell the story about the condition this car is in !
- x 8397
Wow! That's looking very blingy Alasdair
That car is going be strutting up and down the concours catwalk in the not too distant!
Looking forward to seeing it on my next visit down your way
- x 1996
It is quite remarkable how clean this car is....31 years old and it is like this behind the arch liners !
- x 8397
That's quite remarkable Alasdair!
- x 1996
And......back to leaky old Citroens.
Above the rear sub-frame....Winter "off road period" is the time to investigate the LHM dampness & occasional drip ! And the odd bracket to have its surface corrosion treated.
- x 8397
Activas and LHM leaks... They go hand in hand
We'll sort it next week between us Alasdair
- x 1996
BOOKED !CitroJim wrote: 21 Jan 2023, 05:46 Activas and LHM leaks... They go hand in hand![]()
We'll sort it next week between us Alasdair![]()
on the plus side for old Citroens
The AX had a clean pass today
- x 8397
Magic
Daffodil's a good girl!
Leak fix booked for Tuesday... I have been given permission...
