Citroen C5 X7 2010, 1,6 HdI - cable loom cut off
Sundiver
Unread post by Sundiver »
Hi mates,
I would like to ask You, what could be this cable used for? I found it in the fuse box compartment below the board/BSI. It is Citroen C5 X7 1,6HdI, manufactured 2010.
Previously I thought, that it would be for the preheat relay, but it is not. Another point is, I have no preheat symbol displaying during engine preheat on the dashboard display when the engine is cold, because the engine doesnt start easily when cold, and has to be started/preheated twice... Any ideas please? Many thanks in advance, Petr :-)
x 6950
Re: Citroen C5 X7 2010, 1,6 HdI - cable loom cut off
The BSI is in the vehicle not the engine bay, so that is likely coming from the engine fuse box or supplies management.
If you look on the wiring sheath, every 2-3 inches there will be a code repeated. If you can get a shot of these codes or advise me for each wire, I should be able to look them up.
Sundiver
Hi Marc,
Thank You very much, I will check the codes underneath the sheath and let You know :-)
Nikolica15
Unread post by Nikolica15 »
Good day everyone.
I have the same situation on my citroen c5 x7 1.6 hdi 2009.
Can someone tell me what those 5 wires are for?
Thank you in advance
x 1060
Unread post by wheeler »
Nikolica15
Thank you very much for your quick response.
