2007 207 cc reversing censor module
bnd
Does anyone know the location of the said module in the car.
- x 6956
Re: 2007 207 cc reversing censor module
It's located in the rear inner wing on a normal saloon, access from the boot behind the panel, so likely in the same location on a CC.
bnd
Cheers Marc
bnd
Quick update. Diagbox diagnostic software showed that the control unit was faulty. Could I find the unit
I ended up pulling the boot apart to follow the wiring. A long story cut short, if you have a faulty reversing assistance control module on your Peugeot 207 cc 1600 cc 2007 the module is sited behind the rear seat back support passenger side. See photos. The rear seating has to be removed ( 4 x 13mm headed bolts with washers.) The bottom of the seat has to be removed 1st before the back can be removed. The control module unit is held onto the metal rear bulk head by 2 x 10 mm nuts. There are to plugs on the bottom of the module which are held in by 2 plastic cam style levers. New module on its way. Hope this helps someone with the same problem. NB The module on the left in the photos ( drivers side ) is the control module for the electric roof incase you ever need to know where it is.
