Hi, new on here with a few questions
Johnbull
Hi. I bought the diagnostics recommended from easy diagnostics but only getting to use it now, fitted new rear pads and set of cables today, and being nosey I've ran into a problem, being an idiot I have went into service and the programme is asking for an interval and I don't know how to get out of this please help I'm lost, apologies
- x 1866
Re: Hi, new on here with a few questions
The image you posted is smeared and unreadable.
Steve Walsh
- x 512
I think it maybee the service interval you want to set the countdown mileage to. Check in your handbook but probably 12000 miles
- x 6956
Johnbull
Thanks, got the diagnostics sorted , stripped back the insulation from the wiring around the battery, really nothing visible, put back together and ran the diag and am getting code u1213 fault in info transmitted by abs/ esp or fse (electric park brake) ECU, also giving fault in fuse box / relay in engine bay, any ideas appreciated thanks
Johnbull
Johnbull
Help needed.
Eventually got back to the Picasso and still have problems, I have checked wiring at the suggested areas but nothing obvious , new handbrake switch fitted , code u1213, is coming up, fault in info transmitted by abs/esp or fse electric park brake ECU, on the dash brake system faulty, abs,esp, faulty. stop and service indicated, there has been new cables and pads fitted, correctly and calibration done. Handbrake still not working, any thoughts on next step please.
Reason: Topics Merged - Please keep related posts in the same topic.
