2006. C3 1.4 Desire. On switching on ignition no error lights. On starting prior to moving I hear a ping and the ABS light
comes on. It stays on until engine stopped.
I checked codes and it throws up only one; P0598 relating to 'Thermostatic heater control unit'.
I am unable to see how this might relate to the ABS light.
Anyone shed a light? Do the ABS cable ends meet anywhere accessible for me to do an OHMS test on them or do I
do each wheel separate?
Thnak you. John. (Does 'Anders' still post on here?
weird error code related to ABS?
- x 5674
Re: weird error code related to ABS?
If you mean Anders DK then not since Nov 2014.
Shame, he is very knowledgeable.
- x 1056
What device are you using to check fault codes? Did you actually scan the ABS system as that seems more like a fault code from the engine management system.
johnhuson
- x 5
Thanks for the comment about Anders......was it really 2014! Checking with a simple OBD2 reader. All error code lists the thermostat housing problem.
- x 1056
Basic OBD readers normally only talk to the engine ECU, You need to read the ABS system as it is an ABS warning you are getting.
johnhuson
- x 5
Thanks wheeler for that. Any ideas in what direction I should look to to narrow down my search?
johnhuson
- x 5
I guess I should dig out my diagbox from my Xantia and C5 days then? I do not remember
how to use it! I need to brush up on operating it.
If anyone near Chester needs a reading I might be able to help.
