To add to this, my SIII Landrover was used for trialling. It had 7.50 Mudpluggers fitted to non standard rims and had tubes fitted. I did a lot of wading / puddles at various depths. The deepest being the bow wave level with the top of the bonnet. I've never seen water in the area sandwiched between the rim and the tube. I've also never cut a tube open to see if there was moisture in there however. The tyres were inflated and deflated regularly to change the psi from road specs down to 20 when off road.
My money is there would have been moisture in the tube from the compressed air. When I was working in the weld shop at Toyota we had to drain the water catchers on the robots shiftly and that's with water catchers further back in the system.
Air pressure
moizeau
- x 423
Re: Air pressure
Pete
Steve Walsh
- x 518
Re: Air pressure
Retrieved the wheel from the murky depths of the water tank, pressure still at 1 bar. Popped one side of the tyre off the rim and got my hand inside with a piece of paper towel. It was completely dry.
Fairly sure that anybody with water in the tyres has been injected via the airline
Have a good weekend, Now the wife has seen me messing with the mower, she wants the grass cutting !!
Huskyxantia
- x 925
Re: Air pressure
From an old mk6 escort van i had i found the old spare wheel from it this morning
Husky.
Huskyxantia
- x 925
Re: Air pressure
Wheel sitting on part of a black plastic bag
Husky.
Huskyxantia
- x 925
Re: Air pressure
Oh well im having 2 new tyres fitted on the 206 later moblie job . Better put my arm bands on !
Husky.
Huskyxantia
- x 925
Re: Air pressure
Ive had water in my wellys before , there made from recycled tyres aint they ?
Husky.
- x 3296
Re: Air pressure
I had a tyre checked recently, and it had two punctures. One let the water in, while the other let it back out again!
- x 1082
Re: Air pressure
Now that's a clever tyre
Champion of Where's CitroJim
- x 8422
Re: Air pressure
Hell Razor5543 wrote: 15 Oct 2022, 15:44 I had a tyre checked recently, and it had two punctures. One let the water in, while the other let it back out again!
moizeau
- x 423
- x 3296
Re: Air pressure
Weirdly, it does. I dropped a small feather into the 'in' hole, it came out of the 'out' hole, went back into the 'in' hole, and is now looping.
Huskyxantia
- x 925
