C5 X7 no start (or only runs for fraction of a second)
- x 2356
- x 2356
Re: C5 X7 no start (or only runs for fraction of a second)
Helper available briefly.
Battery voltage with multimeter reads 12.2 Volts = bit low, haven't done massive amount of cranking today, was charged up yesterday afternoon.
Reading between negative and good earth (starter mounting bolt head) under cranking records 0.2 Volts. This doesn't seem excessive drop (given hundreds of amps flowing at the time) so am hopeful means no high resistance bad earth issues present.
Will get car fed with healthy voltage (Coupe is nose to nose with it, bring it forward should get them less than jump lead length apart)
Is there anything in particular I need to do/ not do when jump leading an X7 C5?
Matt
Matt
- x 1074
Yes, make sure the fire brigade is in attendance for the electrical fire, just to be on the safe side. I'm in no way saying Citroens have terrible electrical issues....
Champion of Where's CitroJim
- x 8412
Having just read through this entire thread I may have missed any reference to it but has the crank position sensor been checked and is it correctly mounted?
I've only done one cambelt job on an X7 and felt the crank position sensor was very vulnerable and easily damaged during pulley removal/refitting...
Just a thought as everything else seems to have been investigated but as I say, I may have missed that it's been swapped...
- x 2356
Hi Jim,CitroJim wrote: 11 Oct 2022, 07:29 Having just read through this entire thread I may have missed any reference to it but has the crank position sensor been checked and is it correctly mounted?
First off - thanks for reading all this long tail!
Crank sensor not specifically checked. Yes is vulnerable, was moved out of the way during the belt change.
Diagbox shows an rpm value during cranking, not sure if this confirms sensor functional or not? But will check, definitely,
Matt
moizeau
- x 423
Check on Diag if Cam and Crank are synced
Pete
- x 8412
I'm reading this thread with great interest Matt and I'm looking forward to seeing a successful conclusion very soon
It might be worth swapping the crank sensor for a known good one as it'll be the only thing that's been disturbed in the process... Sometimes they can check out good statically but still be faulty when in use... The fact that it sometimes starts and then immediately stops may reinforce this train of thought...
I'm not saying it is but given it's been moved around and all else has been excluded...
- x 2356
yes, I have seen that one before, will check it again. Remember it changed from something akin to "not synchronised" to "synchronised" when cranking, but worth double check.
Thanks Jim,CitroJim wrote: 12 Oct 2022, 09:56
I'm reading this thread with great interest Matt and I'm looking forward to seeing a successful conclusion very soonYou have all my best wishes in this and I know we'll all be celebrating once it's sorted
That's a good point about crank sensor, as you say it's vulnerable position (could see a snapping auxiliary belt taking it out potentially too) and has been disturbed to do the belt replacement.
Thank you also for the words of encouragement - very much appreciated!
Matt
- x 1074
My turn for encouragement, Go on Matt.... that's all I have, busy day.......
- x 2356
Thanks Ryan, it all helps spur me along!
Forecast is typically terrible, but will see what I can get done tomorrow
Matt
Matt
- x 1074
It's either you or the crusher, you can save that old girl, patience is the key.....
- x 2356
Ok, rain subsided so fired up my Italian built jump pack
- x 2356
- x 2356
This confused me - airflow shows zero when cranking. Clicking the row says something about EGR so wondering if just a red herring
Can't see anything untoward on any of those.
Easy start trial again after dinner , if weather ok and can borrow a helper again
Matt
Matt
- x 2356
Blimey, time flies and weekends especially so.
Had chance today at last, and still dodging showers.
Coupe connected up as jump start booster again. Intake hose off, under cranking increasingly large squirts of firstly WD40, then brake cleaner (run out of Easy Start, both these are combustible and I believe should do the trick)
Nothing, not even a cough of life. As mentioned by others earlier in the thread, the above suggests timing.
I can (triple, quadruple?) Check the timing again next weekend but was happy last time it was correct.
As per
viewtopic.php?t=42544&start=15
I'm now looking (locally preferably given the need to draft the damn thing there most likely) for someone (I.E. a garage) to investigate and find whatever it is I'm clearly missing.
Weirdly popped up to say hand brake faulty (then message disappeared again) - suspect low battery voltage behind that.
Matt
As per
Matt
