MOT pass, Emissions....
- x 1056
My C8 passed its MOT today, I don't know how but she did. My question is....I have dpf warnings, it says it's faulty etc. So can someone explain these emission results to me please.
Champion of Where's CitroJim
- x 1924
Re: MOT pass, Emissions....
Easy. The sun shines on the righteous.
- x 1056
Pmsl!! I was telling everyone my car is an easy fail which is mine got done before theirs, and she passed!! But the faulty dpf should of made it fail surely. OR is she lying to me with dodgy electrics??
KennyW
- x 163
It could be the one of the sensors are faulty giving false readings.
My son's golf diesel is doing the same.
Kenny
Kenny
C3 1.4 petrol (SWMBO)
- x 2316
Other thing to add is diesel emissions test at MOT: rev engine to governed maximum, unloaded doesn't ask a lot of the engine or fuel system. Unless you've got something seriously wrong (e.g EGR jammed open) or the car hasn't seen redline once in the twelve months since last it was in for the test (some folks labour diesels routinely, year round. That blast of 4500+ rpm clears the pipes somewhat!) Then should not pose too much challenge for MOT emissions test.
A pass is a pass!
Matt
A pass is a pass!
Matt
Ross_K
- x 110
Speaking of sooty emissions, that MOT station needs to clean the toner out of their laser printer
- x 3299
Not a toner issue. Either the photo-optic drum or the fuser is shot.Ross_K wrote: 10 Oct 2022, 21:16 Speaking of sooty emissions, that MOT station needs to clean the toner out of their laser printer
- x 1924
That's the power of this forum. Such breadth of knowledge and expertise.
- x 2941
But nobody answered the op's question.Paul-R wrote: 11 Oct 2022, 08:22 That's the power of this forum. Such breadth of knowledge and expertise.
- x 1480
If the risk of filter clogging warning comes on as soon as you start the engine, and it's done 100k + miles, then the ECU has probably decided the DPF is end of life with the ash content. However as you have seen if the pressure are OK, it will keep working and regenning. Eventually it will cause problems, but in the mean time, you can tell the computer a new DPF has been fitted and the nagging will go away!
- x 1924
Yes I did.
- x 2316
