DS5 2012 Hybrid brake disc size
StrictlyConfidential
x 5
Unread post by StrictlyConfidential »
Hi everyone,
Can someone confirm what is the size of brake discs for Ds5 Hybrid front?
I need to order some from autodoc and have two options: 302mm and 340mm. I am thinking they should be 340mm
x 6954
Re: DS5 2012 Hybrid brake disc size
I shall need the VIN for this vehicle first as there are multiple types including 283....
x 5
VIN number is: VF7**************[VIN obfuscated, can be read by forum staff]
x 6954
Ok 2 things:
1) Your DS5 has an outstanding after sales campaign overdue! I suggest you contact your nearest Citroen dealer and tell them you've been advised of this. They will explain what the work involves, but will be free of charge.
2) As for the discs:
Original Part number: 4249F6, £126.60 each.
Cheaper Alternative, part: 1618864780, £74.48 each.
In both cases yours have a diameter of 340.
x 5
Thanks for the info.
I've booked the recall this morning with Citroen Northampton. I was told it was due to faulty airbags. Always a pleasure roaming this forum 😎
x 6954
No worries, better safe than sorry.
