get this fault code if I push the nemo e.g. flooring pedal . . just recently also now getting a clicking whine when engine under load . . .possible turbo bearing? . . open to ideas and if need to change turbo what oem numbers fit the engine vin VF7**************[VIN obfuscated, can be read by forum staff]
would be gratefull for any assist and advice
Nemo turbo fault p0237
Huskyxantia
- x 933
Re: Nemo turbo fault p0237
Could be vaccum .
Husky.
- x 6950
Here's the specific fault description as it relates to your Engine ECU:
| Fault Code: | P0237 61 |
| Description of Fault: | Turbo pression regulation fault: Pressure too high. Turbocharging pressure too high Context of appearance of the fault code: Engine running Fault confirmation time: 5s Technical precision on the context of appearance of the fault code - The following conditions have to be met: - Absence of the fault code P2226 on the atmospheric pressure sensor - Absence of the fault code P0235 on the turbo pressure sensor - Absence of the fault codes P0069 - P0236 - P0234 on the turbocharging system - Absence of the fault code P2112 on the air mixer - Fuel flow greater than 15 mm3/stroke - Engine speed above 2500 rpm - Difference between the measured turbo pressure and the atmospheric pressure less than a certain threshold dependent on engine speed and fuel flow |
| Conditions for Fault to clear: | Disappearance at the next driving cycle provided no fault for 1s. |
| Downgrade Modes whilst Fault is active: |
| Symptoms: | - |
| Suspect Areas: |
