Citroen Saxo Engine Crankshaft Spacer
x 8344
Today I've been busy fixing a crankshaft oil leak on my Saxo
Sadly, I broke the flange behind the camshaft sprocket... I was damaged anyway but I made it worse... I need a new one...
I believe I've identified the item in question as 'Engine Crankshaft Spacer' and Citroen part number 0512 18. I need to know if it's still available please...
It's the item shown in picture 7.10 of the BoL - they glibly said it would slide off... I had to make up a puller to extract the remains... Very tight.
It needs replacing anyway as the oil seal face is grooved...
Saxo BoL Extract... (c) Haynes
Thanks hugely...
x 6956
Re: Citroen Saxo Engine Crankshaft Spacer
Hi Jim, that part, 051218, (68X30-16,05) is no longer available from Citroen unfortunately. It is item (9)
x 8344
GiveMeABreak wrote: 23 Sep 2022, 17:30 Hi Jim, that part (68X30-16,05) is no longer available from Citroen unfortunately.
Oh ^&%$^... Thanks Marc 😀
Now I have a serious problem....
Huskyxantia
x 899
Unread post by Huskyxantia »
:-D
x 6956
Not in stock Husky - you'll find plenty of sellers who will show the part to get your attention, but invariably none of them will have any stock like this one.
x 8344
Thanks Husky 😀 Shame not in stock...
Marc, can you confirm that 68X30-16,05 is a part number? Have Citroen changed their part number nomenclature recently?
x 6956
No Jim, that's the measurement I added in case it helped you source a similar one. 68 X 30-16,05.
Huskyxantia
x 899
:-D
x 6956
I've moved this out of the Official Part number thread and given it a separate thread and a new title as it's likely to generate a few posts.
Jim, having looked, I can tell you that this part was also common on the following petrol engines:
106
106 RESTYLING
205
205 A PARTIR MOD 1991
206
306
306 (RESTYLING)
309
405
405 SAUF RESTYL
PARTNER
Obviously you will need to check the part against any you find, but this spacer was used on some vehicles in the above. :wink:
Huskyxantia
x 899
https://www.ebay.co.uk/itm/363694283442 ... media=COPY
Might have whats needed if you ask this seller
:-D
Huskyxantia
x 899
https://www.ebay.co.uk/itm/115029131689 ... media=COPY
Also might be worth getting in touch with this seller too Jim
:-D
x 8344
Thanks all, hugely appreciated 😀😎👍
x 1485
Time to fire up the lathe!
x 8344
RichardW wrote: 23 Sep 2022, 20:41 Time to fire up the lathe!
The thought had occurred to me Richard ;)
x 1449
Unread post by xantia_v6 »
These people claim to have one, worth asking.
http://www.peugeotparts.co.uk/page18.htm
