Xsara Picasso Shocks and Springs
Huskyxantia
- x 918
Re: Xsara Picasso Shocks and Springs
Husky.
Tam
- x 10
Thanks guys, going to do it over the weekend, will let you know how I get on.
Huskyxantia
- x 918
Being citroen owners we care for each other
Husky.
Tam
- x 10
Wee update!
Looking on the shock manufacturers site, it says they fit up to 02/07 which it didn't say on Arnold Clarks site. Is there any way to check mm/yy of manufacture for my pic? I see it was registered on 05/07 but don't know when it was manufactured.
Huskyxantia
- x 918
Your log book will give your your cars true build date this should then give a rough idea of the old parts dates. If the shocks fit up to February 2007, april 2007 .. could be the reason the height is to high there for the older car.
Husky.
Tam
- x 10
Thanks mate, I can only see date of registration which was May 2007Huskyxantia wrote: 23 Sep 2022, 18:06 Your log book will give your your cars true build date this should then give a rough idea of the old parts dates. If the shocks fit up to February 2007, april 2007 .. could be the reason the height is to high there for the older car.
OnlineRichardW
- x 1491
I could tell you from the VIN but the site is down at present. The RP number should be on the label with the tyre pressures on the A or B pillar. Online calculator will translate the number to the date.
- x 3296
OnlineRichardW
- x 1491
Tam
- x 10
Thanks 9 April 2007RichardW wrote: 23 Sep 2022, 20:47 I could tell you from the VIN but the site is down at present. The RP number should be on the label with the tyre pressures on the A or B pillar. Online calculator will translate the number to the date.
SwissTony
- x 28
Mine has definitely got lower over the last six months or so.
2011 C3 Picasso in black - The love wagon.
2016 BMW F800R - the throbber between my legs.
Tam
- x 10
Ok, Arnold Clark have let me know that they are the wrong shocks and that they don't stock any for post 02/07, even though I put my reg in and they recommended these. Now to find the correct parts.
Tam
- x 10
Can someone please let me know the part numbers for the shocks? Unsure which ones from above I should be referencing.RichardW wrote: 21 Sep 2022, 20:16 Springs
5002 QL
NFP
02
FRONT SUSPENSION SPRING
MARK 1 YELLOW OR 1 WHITE + 1 ORANGE
Struts
01
5202 PJ
LE-2014
01
FRONT SUSPENSION DAMPER
LEFT
ENS
link to corresponding labour times
16 746 982 80
01
E:FR SHOCK ABSORBER PSA
GAUCHE
- AND AGE >= 3
5202 PK
LE-2014
01
RIGHT
ENS
16 355 416 80
01
DROIT
- AND AGE >= 3
OnlineRichardW
- x 1491
Left is 5202PJ, or cheaper part for older cars: 16 746 982 80; right 5202PK, or cheaper 16 355 416 80
There's no age range specified on these, they seem to be common to all diesel models, except early 2.0 HDis. The struts won't make the ride height high, they have no support role, this is provided by the springs (they could however make it low by being short and causing the unloaded length of the strut to be less).
Tam
- x 10
Thanks RichardRichardW wrote: 24 Sep 2022, 20:57 Left is 5202PJ, or cheaper part for older cars: 16 746 982 80; right 5202PK, or cheaper 16 355 416 80
