Xsara Picasso Shocks and Springs
x 1485
Re: Xsara Picasso Shocks and Springs
That's not right... random Xsara Pic selected off ebay:
You don't really want to drive it like that, it will ruin the control arm bushes in short order!
Something has gone wrong, can't think why both sides should jack up when it didn't with the first. I would check that you have the spring seated properly , if not then the spring is probably wrong - either wrong length or wrong spring rate. Can't say I've ever noticed a car 'settle' after a new spring is fitted, and certainly not by 2" or more!!
SwissTony
x 28
Unread post by SwissTony »
Had mine done about 6 months / 4000 miles ago, it was way too high at first, now it's settled to normal..
2011 C3 Picasso in black - The love wagon.
2016 BMW F800R - the throbber between my legs.
Tam
(Donor 2022)
x 10
Unread post by Tam »
Am I right in saying the springs are the likely issue rather than the shocks?
danlat1415
x 24
Unread post by danlat1415 »
If you already replaced a spring initially, before replacing the shock absorbers, and you didn't have any issue when just the spring was replaced - then it's unlikely to be the spring.
If you're not sure/don't remember - then it could be either the spring or the shock.
The Xsara Picasso has different engine sizes and models, so different variations/weight ratings for the shocks and springs - so may be that you have shocks intended for a heavier model, and as yours is lighter than intended, isn't compressing as much as they should.
Sometimes parts websites don't list the correct model.
Tam
(Donor 2022)
x 10
danlat1415 wrote: 20 Sep 2022, 21:23 If you already replaced a spring initially, before replacing the shock absorbers, and you didn't have any issue when just the spring was replaced - then it's unlikely to be the spring.
This makes sense-Thanks
I dumped the originals i'm afraid so back to the drawing board.
Guys, can you assist with the correct part numbers(Shocks and springs) using my vin please? TIA
VIN VF7**************[VIN obfuscated, can be read by forum staff]
Tam
(Donor 2022)
x 10
Re: Xsara Picasso Shocks and Springs (Part nos)?
Tam wrote: 21 Sep 2022, 10:48
Guys, can you assist with the correct part numbers(Shocks and springs) using my vin please? Even any docs with dimensions for shocks would be great. TIA
VIN VF7**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]
x 1485
Springs
5002 QL
NFP
02
FRONT SUSPENSION SPRING
MARK 1 YELLOW OR 1 WHITE + 1 ORANGE
Struts
01
5202 PJ
LE-2014
01
FRONT SUSPENSION DAMPER
LEFT
ENS
link to corresponding labour times
16 746 982 80
01
E:FR SHOCK ABSORBER PSA
GAUCHE
- AND AGE >= 3
5202 PK
LE-2014
01
RIGHT
ENS
16 355 416 80
01
DROIT
- AND AGE >= 3
Huskyxantia
x 888
Unread post by Huskyxantia »
myglaren wrote: 20 Sep 2022, 12:37 That does look to be a very large gap.
I agree
:-D
Huskyxantia
x 888
I have a suspicion they may have used tye face-lift type parts the mark 1 is funny for sizes of parts just on the pre and post face lift time line , example headlights are not as wide on the facelift mk1 to the pre mk1, so maybe the suspension set up could be a little different , theres different sizes too with the bonnets around 2003 . Also model type has slight size differences.
:-D
Huskyxantia
x 888
RichardW wrote: 20 Sep 2022, 14:45 That's not right... random Xsara Pic selected off ebay:
This was how my ride height looked when i had a picasso.
This is spot on.
:-D
Huskyxantia
x 888
Heres my old picasso .
Huskys push me pull me
:-D
Tam
(Donor 2022)
x 10
Huskyxantia wrote: 21 Sep 2022, 20:24
This is spot on.
So did mine before changing. :-D
Huskyxantia
x 888
Different cars
Ive changed the front legs on my 206cc the height was pretty much the same after the job was done
Also my old zx estate the height didn't rise much both heights are the same over a year later,
As for waiting 6 months for the gap to go back to normal i find that a bit concerning as to why this compression would happen
Even looking at the photo the leg angle looks like its leaning im not a professional mechanic but if that was my car id be going back to the place that undertook the job and ask them if its the correct height , six months to settle , it only takes a few feet to settle when you've had the car jacked up for a while. I asked for the photo to be uploaded , when i saw the gap it made my stomach turn , it might be worth seeking some help from citroen main dealer regarding the height, id say if yours is a petrol and the parts were meant to take the diesel weights then this might be why its as high as it is
:-D
x 1485
I can't remember the arrangement at the bottom of the strut, but I think it's inserted into a clamp rather than a bolt on type. I'd check that the strut is properly seated in the hub both sides first.
Huskyxantia
x 888
Richard your correct they sit in a clamp and i think there's a bolt and nut that holds the hub housing to the strut.
:-D
