RP Number
JohnD
(Donor 2022)
x 72
RP Number
Unread post by JohnD »
Anybody tell me where to find the RP number on a 2002 Xsara. In the place where Haynes says it is, there's a semi permanent plastic trunking fitted right across the engine bay.
x 1044
Unread post by wheeler »
it should be on the label where it tells you the tyre pressures under the o/s/f door checkstrap.
x 94
Unread post by citronut »
no the RP No is not on tyre presure lable it is usuly stenceled on or around inner wing and suspention turret regards malcolm
ActivaV6uk
Unread post by ActivaV6uk »
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by citronut</i>
On all my phase 1 activas the is true but on my new X reg HDi i cant find it i will check the inner wing.
Andy
x 94
it allways used to be in yellow paint but i have see it in black,on xantias i have usuly found it behind susp/turret regards malcolm
Jon
Unread post by Jon »
On late cars, 2001> it is most definately on the tyre pressure sticker as Wheeler says. This is the case with my 2004 Berlingo.
I can take a picture if required.
What confuses people is that on these later cars, the RP number begins with a Zero and ends with 2 letters, like FV. My Berlingo reads 09926FV and was built on 12/1/04, considering that I registered it on 21/1/04, that is pretty good! Obviously, very recent RP numbers (after April 04) do not have the Zero in front, and begin 1, e.g. 10004FV.
JohnD
(Donor 2022)
x 72
Many thanks for the help. We looked all over the inner wings and suspension turrets at the weekend but couldn't find anything resembling the Saxo's and Xantia's RP stencil. We looked at the figures on the tyre pressure label but didn't recognize an RP number. Having read Wheeler's post and also the reference on page 38 of GSF's Cit/Pug catalogue, the mystery is solved.
x 94
are you going to let us in on the secret or do i have to wait till i go to my workshop 2morrow and read page 38 of my GSF cat regards malcolm
Jon
[img]/images/berl_rp.jpg[/img]
