Error message on c4 picasso app Faulty Engine Control System:
Mexico14
Re: Error message on c4 picasso app Faulty Engine Control System:
Unread post by Mexico14 »
GiveMeABreak wrote: 30 Aug 2022, 17:02 Well it depends on the quantity of fluid they need. 3 Litres on the aftermarket is anywhere around £115 plus delivery, then there is the labour and of course the resetting of the additive counter. So that's about the rate.
Could you check what spec of fluid/quantity I need please? Is mine a solid bottle or pouch?
x 6945
You need Powerflex Additive and you have a reservoir not a pouch, so will need a filling kit.
Mexico14
Is that only available through the dealers? Should I inform the garage I'm using that it cannot be anything other than "eolys powerflex" otherwise it could cause problems?
x 6945
That is the correct fluid.
You can purchase this in 1 to 3 litre containers with or without the filling kit if doing it yourself, but the engine ECU will need to be informed it has been replaced and the additive counter reset, so depends on whether your mechanic has a professional level diagnostic tool and software to do this.
Mexico14
Hey, check out QUINTON HAZELL Fuel Additive in the AUTODOC app https://m.autodoc.co.uk/quinton-hazell/17224449 autodoc reckon this one by quinton-hazell is compatible for my car
x 6945
Save your money…..
Mexico14
x 6945
Yes, that's correct, only use Poweflex. That other stuff you linked to in your previous post is not DPF additive fluid.
Mexico14
The plot thickens. I've just checked the quote from the main dealer 1623961680 is the part number on estimate sheet and Google suggests this is eolys "extend" is that different to "powerflex". Has the dealer made an error?
admiral51
(Donor 2026)
x 391
Unread post by admiral51 »
Mexico14 wrote: 06 Sep 2022, 19:21 The plot thickens. I've just checked the quote from the main dealer 1623961680 is the part number on estimate sheet and Google suggests this is eolys "extend" is that different to "powerflex". Has the dealer made an error?
Has the dealer made an error 90% of not having made an error.
Has Google made an error and said it fits your vehicle 90% yes.
Has Marc made an error 99.99999% no.( but he is human)
Your vehicle take your pick :)
Colin
Mexico14
Marc's been spot on for everything else, I'm being cautious as this car seems cursed. On more than one occiaon when I've taken something to be fixed it's either not been fixed/they've replaced a part that wasn't the problem/broken a part on my car resulting in more trips to the garage. :x better be safe than sorry.
admiral51
(Donor 2026)
x 391
Yes totally agree with you
x 6945
You build date is 14483 (4 July 2016).
You need Powerflex, not Extend, as your vehicle's build date is 14483. Eolys Extend was for certain earlier vehicles and a replacement for INFINEUM F7995.
I can't say it clearer than that, but Powerflex is NOT compatible with Eolys Extend and I quote direct from Citroen:
"CAUTION: It is forbidden to mix INFINEUM F7995 and Rhodia EOLYS POWERFLEX additives together."
So I suggest you get the dealer to read the recommended maintenance document listed under your vehicle and it will clearly state:
VehicleRPO numberType of product
(Cap colour in additive kit)
Part NumberColour of the click-fit
(On the vehicle)
Packaging
Vehicles All Types
(Not 508 (W2), 607 restyle (Z9), 407(D2), C5 (X7), C6 (X6))
From RPO 12166Eolys POWERFLEX (blue)9736 A0
9736 A1
Blue
Blue
1 Litre Container
3 Litre Container
What they have told you is basically to use an older additive from older vehicles in a later vehicle designed for the later fluid! I suggest the parts bloke goes back on the training course and you contact the Service Manager as the consequences of mixing these up could shaft the pump.
Mexico14
Cheers Marc, much appreciated.
