I have a Citroën C1 which is bought used. I got it for cheap as the service history was not known for 80.000 km. The car has done a total of 171.000 km. It is now using some oil. When I fill the oil to the maximum mark on the dipstick it takes around 1500 km for the oil level to get to the minimum mark. I'm suspecting bad valve stem seals as it is smoking when revved.
I'm planning on doing a compression test soon. I've also checked for oil leaks and I couldn't find any. Is there any other thing than this I could check?
Best regards
Nikola
Citroën C1 1.0 high oil consumption
Nego2403
- x 1055
Re: Citroën C1 1.0 high oil consumption
Might Be worth also checking the turbo bearings for excessive play, this could allow the oil that is used to lubricate the turbo to be burnt.
I would also take the air intake off (after the turbo) at the lowest point & check for excessive oil in there.
Nego2403
There is no turbocharger on this engine. The engine is the 1KR 1.0 petrol engine.wheeler wrote: 01 Sep 2022, 19:32 Might Be worth also checking the turbo bearings for excessive play, this could allow the oil that is used to lubricate the turbo to be burnt.
- x 1055
Sorry. I thought it was the DV6 engine in your profile
citroenguy
- (Donor 2021)
- x 73
Hi
Oil burning is very common on high milage mk1 C1/107/Aygo.
This Daihatsu/toyota engine isnt the best..
New rings, pistons and oil squirters seem to be the remedy
I have various repair handbooks and wiring diagrams for C5 mk1, Xantia, XM, Berlingo and C3 mk1.
I have Lexia/Diagbox (Sweden) and Servicebox/sedre
Nego2403
What should the compression be for this engine? So you would think an engine rebuild or replacement is the way to go? It's running fine and I don't have any other problem with it. Although it has some ticking which I think is pretty normal for these engines.citroenguy wrote: 03 Sep 2022, 08:32 Hi
citroenguy
- (Donor 2021)
- x 73
In my doc backup PSA dosen't specify any compression figures.
But on a petrol engine "healthy" compression should be circa 10-14bar if my memory serves.
Usually one cylinder is lower than the others.
Yes i'd recommend a bottom end rebuild or short block.
A second hand engine feels like a false economy since the "new" engine will fail eventually, like the original one.
Nego2403
When doing this maybe remove the whole engine and also do the valve stem seals? It has decent amount of smoke when the rpms are highcitroenguy wrote: 03 Sep 2022, 17:28 In my doc backup PSA dosen't specify any compression figures.
citroenguy
- (Donor 2021)
- x 73
Sounds like a plan!Nego2403 wrote: 03 Sep 2022, 19:28When doing this maybe remove the whole engine and also do the valve stem seals? It has decent amount of smoke when the rpms are highcitroenguy wrote: 03 Sep 2022, 17:28 In my doc backup PSA dosen't specify any compression figures.
