C5 X7 signal from fuse
This section is for General Enquiries or for Systems not Covered Above
vodnasol
(Donor 2026)
Unread post by vodnasol »
Hi all, I have added a subwoofer to my car and I need to get 12V to turn on the sub amp when the engine is running. I tried F4 and F7 fuses(with a fuse holder add-a-circuit), but neither worked(0V on the multimeter). Is there another place from where I can get 12V when the engine is running?
My VIN is VF7**************[VIN obfuscated, can be read by forum staff]
Ross_K
x 110
Re: C5 X7 signal from fuse
Unread post by Ross_K »
Assuming this is a C5 X7, G39 in fuse box A is the designated (factory-installed) amplifier circuit - 30A fuse so should give you 360W?
vodnasol
(Donor 2026)
I already have ran the main power wire. I'm asking for a place to get 12V when the engine is running for the remote terminal of the amp, which turns on the amp.
x 1049
Unread post by wheeler »
Are you using the original or aftermarket radio?
vodnasol
(Donor 2026)
wheeler wrote: 29 Aug 2022, 15:36 Are you using the original or aftermarket radio?
The original RD4 radio.
