Zelandeth
x 1603
Unread post by Zelandeth »
Gibbo2286 wrote: 09 Aug 2022, 07:58 My experience with Italian car electrics tells me to always go for the ground/earth connections first, they use crown shape steel (instead of brass or copper) push on connectors bolted to the body panels, they rust badly and become high resistance in no time.
Shouldn't be an issue in this case as everything involved grounds directly to the bodywork through the respective mountings - all of which have been cleaned and greased. Engine and body earth straps are in good condition, and I did experiment with adding jumpers there just to see if it changed anything.
This definitely seems to be a supply side issue rather than grounding. Though I'm absolutely sure there are plenty of grounding problems on the car - the readings on the oil pressure, temperature and fuel gauges going up by about 1/8" when you turn the headlights on I'm sure is because of something like that!
That however is a can of worms I'm not getting involved in right now, it's running as well as I think it's going to without the carb getting some serious attention from someone who knows their stuff, so I think it's time it was sent home.
Current fleet:
Zelandeth
x 1603
Moderately busy day today. It started out helping a friend carry some parts for a car they were having delivered today. The Caddy is supremely useful at times like this.
With that car deposited it made sense to also pick up something I've been waiting to have delivered for quite a while now as it was dropped off at the same location.
Which magically materialised at my driveway 15 minutes later.
My original plan had been for the BX to move on first, but transport for that is still pending a confirmation date so we now have an excess of beige.
This means I now have the car somewhere where I can start working on improving it.
The missing tailpipe will be a simple enough fix for now. I had this bit of pipe still sitting around from when I was messing around with the system on the Jag.
Which happens to be exactly the right diameter, length and even has a swadged end so I can clamp it straight on the existing pipework. All I need to do is add a hanger and then this can stay as it is until I track down the correct silencer. It does actually sound quite pleasing at idle but I suspect it will be boomy when actually driving.
Sadly with the weather forecast this week being in the 30s for the rest of the week I can't see me getting much done.
While I was out and about a couple of packages arrived for me.
The first contained this.
That is an original Sinclair QL power supply. I had been looking at coming up with a modern solution, however this popped up on eBay cheaply enough it just wasn't worth the hassle.
The second was also for the QL, but this time a modern replacement keyboard membrane.
You can clearly enough see where the original one has cracked where the cable flexed.
With the new membrane fitted and the power supply hooked up we do now have a working QL.
Will need to take some time to get to know the machine when I get a chance. It's probably the single one I'm the most actively curious about that I've come across for a long while.
Current fleet:
Zelandeth
x 1603
Time to take a little look at the Cavalier.
First up, I of course have my priorities right and had to fix this.
Before:
After:
Doesn't that look so much less neglected now?
Some further observations.
[] Stereo wiring. This is going to require some immediate attention before it makes me tear my hair out.
Especially as I've ascertained that several of those wires are live.
[] Those tape holders need to go.
They just look wrong in a 70s car to me. Likewise the 80s gear knob and gaiter. The gaiter I can probably live with, but the gear knob is just wrong and looks totally out of place.
[] Heater fan is non functional. We knew this going in. It is drawing power so is probably just seized up from sitting. Access is okay it looks like we it's all in the engine bay.
Also on the subject of heating, the temperature slider is seized.
[] Dash lighting looks to be 3/5ths working. We have 50% of the instrument panel and the heater controls. Half the dash, rear window defroster switch and the clock are currently not working.
Speaking of the rear window demister switch, I was kind of surprised to find that the indicator tab on the switch to show it's on is purple...I was expecting white, maybe orange or green...but not...purple.
Random detail, but it pleases me.
While on the topic of colour, my camera really can't pick it up but the main beam light on the dash is a really nice ultra saturated deep blue. In fact all of the lights on the dash are very, very vibrant (in a way that sends CCD based cameras running screaming in terror). It's pretty much useless trying to photograph the red ones, they just turn out magenta.
Yes I'm going to geek out over the dash... it's an aspect of automotive design I've always had a big interest in and I greatly enjoy seeing examples like this where a designer has managed to inject a little flair into what is actually a very basic panel that could have been utterly boring and still worked just as well.
[] Ignition light is intermittent. Just a poor lamp holder contact it seems as tapping the dash gentky always wakes it up.
[] Windscreen washers don't, and the wiper blades are precisely as wrecked as you'd expect.
[] Clutch release bearing (or throw out bearing to our American readers) is really rather noisy. Yes, this is how easy this car starts.
[] Rear parcel shelf. Some very 1980s carpet covering the speaker holes. I will be wanting to put some decent speakers in there anyway...so the fact someone has already hacked some holes in there in my mind is a really good thing given it means I can do that guilt free.
[] Door dents. I've had a couple of suggestions for folks who might be able to improve this situation so will see where that goes.
I've picked up oil and an oil filter for it...that amounts to the grand total of what my local factors can get for this car in terms of service items, so I'll need to do some online shopping it seems.
Current fleet:
x 2938
The boot says 'automatic' and you have a 'clutch release bearing' ?
Zelandeth
x 1603
Gibbo2286 wrote: 12 Aug 2022, 09:07 The boot says 'automatic' and you have a 'clutch release bearing' ?
While this car was originally an automatic it was converted over to a 5-speed manual using a Manta gearbox some years ago.
Current fleet:
x 2938
I sort of guessed that Zel but had to ask. :)
Zelandeth
x 1603
Quick job today was to bridge the broken bit of the vent line from the fuel tank. Oddly just one bit had gone crispy and shattered, the rest of the tube is perfectly pliable. So just stuffed a bit of fuel line to replace that little part.
Apparently this worked as the boot (and by extension the entire interior) no longer stink of fuel.
I have also got into the back of the heater blower and drowned it in penetrating oil. I suspect I need to pull it to bits and clean up the bearings directly, but will see if this helps tomorrow.
I notice that I'm missing the cover from the back of both headlights. Anyone still got any of these floating around in a box somewhere?
I noticed something...or rather noticed the absence of something in the cabin. Not actually missing, rather something the car just has never had.
Here are the grand total of your driver controls.
Nothing down here aside from the radio if it was still there.
Figured it out yet?
No rear fog lights! Welcome to 1978 I guess!
While they are all holding air, the tyres definitely won't be going anywhere near the road beyond possibly a walking pace trundle round our block.
Changing these was already on my plan, immediately below "make the brakes work" anyhow so no surprises finding that perishing.
Cleanup of the QL is underway.
Keycaps and latterly plungers all removed.
Fun fact, keyboards are gross.
Was surprised to find that the key caps are reverse moulded rather than just being black plastic with a silk screened legend on. Given Sinclair's usual approach to cost savings I hadn't expected this.
Soon enough we had a pile of bits ready to carry downstairs to get a good old scrub up.
Before:
After:
Likewise over the other side.
Before:
After:
All just waiting to be thoroughly dried out now before it gets reassembled.
Should look like new once it goes back together.
Current fleet:
x 8122
I came across this and wondered if some of the gallery pictures may be useful for you Zel! :-D
BFTW
BFTW
Pictures here
Zelandeth
x 1603
mickthemaverick wrote: 14 Aug 2022, 11:51 I came across this and wondered if some of the gallery pictures may be useful for you Zel! :-D
Pictures here
That's a clean one!
QL is now back together and working again.
Does indeed look like a new machine again. Plus the gritty keyboard action has been resolved. Don't get me wrong, it still wasn't ever going to have IBM worrying about the sales figures for the Model M, but it's entirely usable.
For all it's flaws it really is quite a smart looking machine I think.
I think this is probably one of the machines I've had in terms of how well it came up with a clean.
Just need to round up some software for it now so I can try it out. This is one case where I probably *will* wind up going down the SD card based storage solution for as it's otherwise a bit of a pain to interface with - especially as it formats microdrive wafers differently to the Spectrum so I can't just use that as a bridge. Plus they have never exactly had a reputation as the most reliable storage medium, even back in the day.
Current fleet:
x 8122
Zelandeth
x 1603
You couldn't make that up...There's a box full of Sinclair Microdrive wafers in one of the pictures there!
I had to make a point of looking at this one on an actual computer where I could zoom in for a closer look as it looked like it might be a Mac SE/30 which is quite a desirable machine as it's quite capable. The SE1/20 that is though doesn't really offer anything beyond the SE that I already have (other than including a hard drive as standard - which mine has already been upgraded with). Peripherals would be nice, but factoring in the costs of collecting it it would have to go really, really cheap to be worth it...plus I REALLY don't have room for anything else right now! Most of the stuff I collected a few weeks ago is still stacked on top of the pool table, despite that though my room is like a real life game of vintage computer museum Tetris right now.
Getting some racking installed in the one loft so I can store things neatly and in a way that they don't just get buried and forgotten about is high on my to do list at the moment.
Current fleet:
x 8122
I'll take that as just interest in the Sinclair microdrives then! :-D I have a friend who lives in Brighton and would collect from the auction for bringing with him next time we meet. As such, if I find any other lots of interest to me I'll put £20 on the computer with a view to reselling it on ebay minus the sinclair bits and as long as I cover my costs I'll drop them into you next time I'm up that way. No promises though because I may not find anything else to make it worth registering!! :-D
Zelandeth
x 1603
Very much doubt you'd struggle to cover your costs plus some there based on having a quick look at recent sold items on eBay.
The Mac is one of those machines I really ought to try to actually do something useful with at some point. Was lucky enough to pick it up for next to nothing before their values started going silly, but it's not really seen much use since. I've always felt that the OS was quite slow and clunky...but having come to it from RISC OS on one side and a pretty well kitted out, accelerated Amiga on the other that's maybe not the fairest comparison!
Current fleet:
Zelandeth
x 1603
Had a spare hour this afternoon so got a bit of tinkering on the Cavalier done.
Surprisingly the heater blower motor had freed up while it was stewing in penetrant, so I quickly threw that back together for testing.
This was then left to run under careful observation for half an hour or so. The bearings are a bit grumbly so I think it will want replacing long term. It's definitely working on both speeds though and seems to be shifting plenty of air on both speeds.
While staying in the vicinity to keep an eye on the blower to ensure it didn't burst into flames I was successfully able to free off the temperature blend flap in the heater box, so the temperature control now also works properly.
I've confirmed that it does actually supply hot or cool air properly depending on the position as well rather than just the lever moving and doing nothing. The action has come back pretty good actually, which I wasn't banking on as the linkage was quite crusty.
Didn't even get much by the way of junk out of the vents.
I think a new set of heater hoses should probably be on my shopping list.
Mmm...crusty. Though after 44 years I think we can forgive that and say they've done their time.
Think in the interests of reliability I'll be looking to change all of the coolant lines. I need to pop the aux belt off and check to see how the bearings in the water pump sound, as something is making a bit of noise, most noticeable when the engine stops. Reckon it's either the water pump or the alternator.
Spotted this light in the boot somewhat at random.
Initially this caused a bit of head scratching as I couldn't immediately find the switch. Turns out to be quite a tiny little thing hidden behind the nearside hinge mount.
It's a little normally closed switch which is pressed by the hinge as the boot lid is closed.
Initially this was resolutely dead. Turned out we had a poor contact on the power supply lead, in the lamp holder itself *and* at the switch. Once all of these had been cleaned up we had a working light.
Of course having established the light worked there was a very important test to then be made.
Excellent, yes the light does actually turn off when the boot lid is closed.
While not massively bright it is actually useful.
Upgraded with an LED lamp like I used in the boot of the Jag I reckon that would work pretty well.
While the windscreen washers did very briefly work, they immediately died. This turned out to be because the reservoir was full of slime. No surprises there then.
This was left soaking for several hours with a dishwasher tab in.
This didn't really do anything so it's been left with some bleach in to see if that will do anything to it.
I have also bolted my temporary tail pipe on, just need to come up with a hanger for it and I can tick that off the list of things I need to worry about for a while.
An order of about £200 worth of miscellaneous bits and pieces has gone into Autodoc. Given that none of my local factors could find anything beyond the oil and filter (or bother to actually pick up the paper catalogues) so the internet it was to be. Beyond this order the items I'm aware of still needing to pick up before we can think about taking our first tentative, 10mph test run round the block will be a pair of front brake calipers (or at least a rebuild kit if I'm really lucky), a set of tyres and I think I'll just plan on replacing all of the coolant lines.
Sure we'll find plenty more things to add to that list once we start digging!
Oh...wiper blades. See? Told you I'd have missed something.
Current fleet:
Zelandeth
x 1603
Not been much to report lately as I've been rather busy elsewhere. Simply put, trying to unearth the room we refer to as The Purple Room. This is a room which juts off from the side of our lounge (it basically is a second lounge). It's always been something of a dumping ground, but with the move to working from home over the last couple of years it had turned into a complete and utter disaster. You literally couldn't walk from one end of the room to the other, much less use the space for anything. Given we need to have two adults staying in here for a week and a bit IN a week and a bit, we needed to sort it!
It took a whole lot of work...and has resulted in approximately half the rest of the ground floor now being a complete disaster, but the target of our efforts now looks like this. First time it's really been a usable room in about five years.
No prizes for guessing why we refer to it as The Purple Room.
There's now room to fold out the futon (which only folds out to sleep one person despite being wide enough to be a double - daft design) and to put out the camp bed currently propped against the far wall and still walk around. I also put the curtains up as we'd never got as far as doing that before. Putting up the curtain rail in the bay windows was an utter swine of a job.
Yes that room is as odd a shape as it looks. There is not a single 90 degree angle on the floor plan. It used to be a lean to containing a combined heat and power unit when the house was built, before being closed in and turned into a room back in 1986 (when I reckon the carpet dates from). The fireplace is where the gas supply to the generator unit used to be.
Star has decided that she is a big fan. She doesn't like going into the main lounge (she has serious anxiety issues), however she seems happy in there and definitely approves of there being a sofa where she can actually spend time with me. I approve of not having to be sitting on the floor to do this.
Happy face.
Aaaaand *zonk.*
If she's somewhere she can glue herself to my side she's happy.
With 95% of the weekend having been consumed by that job I was determined to get half an hour spent on car things. So I went and sat in the Cavalier and looked around for an easy quick job. Decided the semi functional dash lighting was a good target.
Once I figured out how to get the rear window demister switch out (there's a recess to hook something behind above the symbol, then it just pulls straight out) it was pretty obvious why that light wasn't working.
Simple lamp replacement had that back up and running.
Photo makes it look far brighter than it really is.
Didn't expect to see the symbol change colour to show when the switch is on on a car of this age. Nice touch. The camera hasn't really caught the colour right, but it's a kind of magentaish colour rather than red or amber, matching the marker on the switch. Camera has made it look more orange than it really is.
I've confirmed that there is no facility for illumination of the symbol above the headlight switch, so we're not missing a light there.
Next up will be the instrument cluster. We're missing the offside panel light and the ignition light has a touchy contact. As it's a bit of a faff to get into because of how the heater controls are built into the dash cowling I'm probably just going to replace all of the lamps in the dash and the heater controls as a batch. There's no lamp actually in the heater blower switch, it's lit from above by the one in the lower end of the heater controls via a little window.
Reckon the next task I'll have for this car will be an oil and filter change. The oil isn't that dirty, but it does smell quite fuelly so I'd rather get it changed sooner than later.
Current fleet:
