Alwight all.
This this the injector bar off my new multipoint:
http://www.citroen-pr.net/catalogues/il ... 40044A.gif
Does anyone know where the fuel return pipe goes?? Any pics / diagrams would be helpful too.
Cheers
Ro
Fuel Return
jeremy
- x 8115
The regulator is normally a capsule type thing with four orifices. High pressure fuel in, regulated fuel out to the fuel rail (would go to item 5 on your pic), excess fuel return back to tank and a vacuum sense from the inlet manifold to regulate pressure against manifold depression. Normally they're on the end of the fuel rail but can be remote. What engine?
rossnunn
Its a 1.4i Multipoit, TU3JP out of a 1998 306. It has the square, flatop inlet manifold rather than the round type.
I have a feeling it may have been removed, as I cannot see anything that resembles the description above.
The screw thing on the end of the injector rail (no. 5) is described as a bleed screw.
- x 1044
