Hi has anyone fitted a xsara/xantia front mount intercooler to there 306 or zx? if so how did you do it? i managed to connect it up for a little while but wast sure how to mount it and what fans to use, also had to use the smaller thicker radiator out of the citroen.
Has anyone any advice cause when i had it fitted it i had the boost at 23psi and it pulled 10 times better than the normal intercooler
cheers
306 Intercooler Help
rossd
cozziepj
- x 8411
cozziepj
that was the bits i was using the right angle bit of pipe that comes off the turbo was squashed between the brake servo and the inlet manifold. looks like it would be easier to get a new pipe running towards the gearbox then turn at a right angle towards the intercooler, but dunno where to get something like this from
rossd
