c.morewood
x 55
Unread post by c.morewood »
xantia_v6 wrote: 07 Aug 2022, 19:07
GiveMeABreak wrote: 07 Aug 2022, 10:01 Hi Chris
Not sure which pipe you want so here are the ABS pipes. Let me know which one you need the part for:
Brake Piping
I think the only rubber hose to the ABS block is the return hose to the LHM reservoir. It would be on the return lines diagram, probably part of a complex harness.
Thanks, I did suspect that. I'll get a pic tomorrow.
'00 Xant 110HdiSX Est 83K "W"
'98 Xant 1.9TDSX Est 150K "T"
'97 Xant 1.9TD 20k Est
'94 Fiat TipoTd 40K
pejcicbozidar
Unread post by pejcicbozidar »
Hi to all,
I need info about Eolys Powerflex refill procedure. I cannot find on internet accurate information, is it pouch or tank. I plan to buy refill kit but I am not sure what option is the most recomended.
Eolys content: 1080ml
Thanx!
Regards,
c.morewood
x 55
c.morewood wrote: 07 Aug 2022, 22:43
Brake Piping
Yes its part of the Octopus. Are they the same for all Xantia? The pipe last split 2 years ago, I've managed to shorten and reattach it, but I think this might be the last time due to its length.
Thanks,
'94 Fiat TipoTd 40K
x 6957
c.morewood wrote: 07 Aug 2022, 22:43 Thanks, I did suspect that. I'll get a pic tomorrow.
I was originally going to post this, but kept to the ABS!
Let me know which one you need the part number for.
x 6957
Your vehicle has a reservoir, not a pouch, so you need a refill kit. It uses Powerflex additive and is gravity fed. Don't forget you will need to reset the additive counter using professional level diagnostics like Diagbox after you have filled it, otherwise the engine ECU will not know you have refilled it.
The tank is located at item (16):
c.morewood
x 55
GiveMeABreak wrote: 08 Aug 2022, 12:37
No1 please Marc. I believe that is the return from the ABS at the bottom.
Thank you,
'94 Fiat TipoTd 40K
x 6957
Ok so item (1) part: 5270R6, (no longer available) Chris....
... but have a look here:
https://www.drxantia.com/index.php/en/p ... set-detail
pejcicbozidar
GiveMeABreak wrote: 08 Aug 2022, 12:44 Your vehicle has a reservoir, not a pouch, so you need a refill kit. It uses Powerflex additive and is gravity fed. Don't forget you will need to reset the additive counter using professional level diagnostics like Diagbox after you have filled it, otherwise the engine ECU will not know you have refilled it.
Thank you very much, Marc!
It will be no problem with DiagBox.
Regards,
x 1347
Unread post by xantia_v6 »
GiveMeABreak wrote: 08 Aug 2022, 14:44 Ok so item (1) part: 5270R6, (no longer available) Chris....
They also sell the parts individually, but they only have LHD parts (where relevant) so some hoses may require lengthening or trimming
c.morewood
x 55
Thanks Marc, there are some on Fleabay for considerably less than 181 Euro.
But I've ordered one as a spare as there's no room to cut the current pipe any further.
Thanks for your help,
'94 Fiat TipoTd 40K
Huskyxantia
x 766
Unread post by Huskyxantia »
Hi marc, do you have parts numbers for the rear ns passenger rear window plus diagram 206cc mines getting a little stuck when the window comes up , i think there's a spring missing on a part that holds the window to the mechanism vin number is
VF3**************[VIN obfuscated, can be read by forum staff] many thanks
:-D
x 6957
Rear Quarter Glass
9203FN (Left)
9204J0 (Right)
Both no longer available from Peugeot.
Any other 'bits' you need part numbers for let me know.
Huskyxantia
x 766
Cheers marc, this has sorted what i need.
:-D
x 3277
Can anybody tell me which a/c compressor was fitted to this C3? VF7**************[VIN obfuscated, can be read by forum staff]
x 6957
@Hell Razor5543:
OEM Part: 9822826880. (SANDEN INT- - SD6C12 C1P4 1364 ) £903.67
Standard Exchange Options:
Part: 6453WL, (SANDEN INT- - SD6C121355 or SANDEN INT- - SD6C121351), £446.58
Part: 1671553680, (SANDEN INT- - SD6C12 1363 or SANDEN INT- - SD6C12 C1P4 1364) £477.67
All VAT Inclusive from Citroen.
