B1601 15 BSI Error code
TiberGt
Unread post by TiberGt »
Hi.
The "Electrical circuit failed: have your vehicle repaired" error pops up every time I start/turn the ignition on.
I ran a diagnosis with Diagbox and I get: B1601 15 -> Central power switch positive (+CPC) relay control fault.
I own a Peugeot 508 hybrid 2012 ( 200 Horsepower model ).
Context:
Today I got some mechanics to try and fix the radiator fan since it's not working.
They tracked down the issue, suggesting I should replace the fuse box located near the battery because they say there's a relay there that's not working as it should.
So, they must have broken something in there.
I tried deleting the errors 3 times with DiagBox and also did a battery reset procedure.
What's wrong and what can I do to fix it?
Thanks.
x 6956
Re: B1601 15 BSI Error code
Here is the fault descriptor for this code, but post up your VIN (automasked on post submission) so I can check this is the same for your vehicle, just to make sure.
Fault Code: B1601 15
Description of Fault: Central power switch positive (+CPC) relay control fault : Open circuit or short circuit to the plus. The control is active even though the control copy is inactive. The control line of the central power switch positive (+CPC) relay is considered active when its voltage is lower than 2,7 V
Fault confirmation time: 1 seconds.
Conditions of activation of the diagnostics: The following conditions have to be met:
- BSI triggered
- LIN networks re-awakened
Conditions for Fault to clear: Control copy active
Time of disappearance of the fault: 1 s
Downgrade Modes whilst Fault is active: None, but this may trigger the "SERVICE" warning lamp Warning message and / or an audible warning.
Symptoms: No supply of electrical components.
Suspect Areas:
  • Connectors
  • Electrical harness
  • Built-in systems interface
  • Supplies protection and management unit
So I would first check and test all the fuses in the supplies protection management unit as these power various equipment, but if the garage have tested it and are confident, then I can't do much more than provide the code description for this fault for you.
TiberGt
Hi,
This is the VIN: VF3**************[VIN obfuscated, can be read by forum staff]
I'll suggest this to the mechanic!
Thank you very much!
Juanjo
Unread post by Juanjo »
Que puede ser ??
x 5672
Juanjo wrote: 05 Aug 2024, 19:29 Que puede ser ??
As this is a British forum, albeit dedicated to French cars, very few of our members will speak Spanish, therefore please ask for help from someone h can write in English for you, or use a translation program such as Google Translate or DeepL.
Como este es un foro británico, aunque dedicado a los coches franceses, muy pocos de nuestros miembros hablarán español, por lo tanto, por favor pida ayuda a alguien que pueda escribir en inglés para usted, o utilice un programa de traducción como Google Translate o DeepL.
