Hi all,
All advise appreciated on this issue. I have a 2012 2.0 hdi 163bhp that when fully warmed up will sit with a high idle of around 1300RPM. This reduces to normal idle (800rpm) when the brake pedal is pressed but goes back to 1300rpm when released. It will also drive at this rpm when the accelerator pedal is not pressed i.e. 50mph in 6th gear.
I have ran a standard diagnostic tool on it and it showed a faulting O2 sensor which I replaced but the issue still remains, I have checked and cleaned all other sensors (air mass, boost pressure, etc,) & connections.
Right now I am stumped.
Thanks in advance for any responses.
Rob.
2012 508 2.0HDi High Idle
- x 5672
Re: 2012 508 2.0HDi High Idle
My initial thought is an air leak in the brake hoses or the master cylinder.
RobTy
Thanks myglaren,myglaren wrote: 18 Jul 2022, 10:53 My initial thought is an air leak in the brake hoses or the master cylinder.
I thought the same and checked the air line from the brake servo, can't see any leak. It's only a short one (about 2 feet long and goes to the side of the head).
- x 1490
Surprised there isn't a code and / or engine management light. This is a default strategy if input is lost / confused from one of the sensors - e.g the throttle position. You need to get some live data and check all the sensor inputs, looking for one that doesn't make sense.
RobTy
Thanks Richard,RichardW wrote: 18 Jul 2022, 13:11 Surprised there isn't a code and / or engine management light. This is a default strategy if input is lost / confused from one of the sensors - e.g the throttle position. You need to get some live data and check all the sensor inputs, looking for one that doesn't make sense.
I'll check out the live data.
Rob.
RobTy
Hi all,
I have had an interesting investigation outcome on this. There was no engine light or service light on. I hooked it up to a "decent" code reader and hey presto, P0272 - cylinder 4 contribution imbalance ". Removed top engine cover to inspect injector and loom and was greeted by a sea of hardened carbon deposits. Almost unable to see cylinder 4 injector.
Seems the injector seal is leaking letting compression with unburnt carbon passed it. An hour later of cleaning you can see the injector. With it running, very roughly may I add you can feel the cylinder compression with your hand at the side of the injector.
So, next step is to keep cleaning, remove and replace injector and all the burnt loom and connections along the way as well as whatever else decides to crumble in my hand. It must of gotten hot under there.
Will keep you posted.
Rob
Rob
Jodypug
Did you find a fix to this please?
Mine is doing exactly the same but tried a couple of garages and they have no idea and I can’t find any answers online
kosa19
Hey, Have you got any news regarding this problem. I am having the same issue. I changed engine, do full renovation of incectors. And still no progrees.
One interesting thing is that when i clear error code form PCM ( P0272) and do PCM test in forscan or other mobile app WITHOUT STARTING ENGINE i got the same error again.
Konrad
Konrad
iv86
Did you find the problem?
.I have the same error and can't find the problem
RulGS82
Buenas tardes.
Hola. Tengo un ford smax 2.0 tdci 140cv (igual que el 163cv) de 2011 con motor psa igual que el autor del primer mensaje. Tambien me pasa que el ralenti se sube a mas de 1000rpm. Piso el freno y baja a las 800 normales.
Borro codigos de error de equilibrio de cilindros, a veces dice que es el 4, otras el 1. P0272, P0263... (los inyectores son nuevos y su cableado tambien, bomba de inyeccion nueva, maf nuevo, sensor de presion de gasoil nuevo).
Reseteo valores aprendidos de inyección ya veces vuelve a funcionar bien y otras tengo que repetir esos mismos pasos con forscan varias veces.
Luego funciona bien unos meses hasta que el problema reaparece.
A ver si alguien que le haya pasado sabe orientarme un poco en que mirar.
Gracias
Gracias
- x 5672
Please post only in English!
Translated with DeepL:-
Hello. I have a 2011 Ford S-Max 2.0 TDCI 140 hp (same as the 163 hp) with a PSA engine, just like the author of the first message. I also find that the idle speed rises to over 1000 rpm. I press the brake and it drops to the normal 800 rpm.
I delete cylinder balance error codes, sometimes it says it's 4, other times 1. P0272, P0263... (the injectors are new and so is the wiring, new injection pump, new MAF, new diesel pressure sensor).
I reset the learned injection values and sometimes it works fine again, and other times I have to repeat those same steps with Forscan several times.
Then it works fine for a few months until the problem reappears.
Let's see if anyone who has experienced this can give me some guidance on what to look for.
Thank you.
Translated with DeepL.com (free version)
Thank you.
