Hi,
So I need some help.
I recently got an MOT on my car and it failed because of the seatbelts(plastic shrouds missing when I bought the car).
I purchased universal seatbelt buckles off ebay and they will fit the car, but whilst I was removing the old seatbelt buckles I broke the seatbelt and the seatbelt will not turn off when I turn the car on as obviously the car believes I haven't plugged the seatbelt in.
It is just a wire now that can't be plugged into my new seat belts.
Is there anyway to turn off the seatbelt sensor on the car, obviously I wear my seatbelt it's just the car doesn't know that.
Could I just cut the wire? Or would I need to take it to a Citroen dealership or a normal garage? Or is there a way I can do this myself?
My car is a Citroen c3 2012 black edition.
Thank you for your time.
HELP, Citroen seatbelt sensor
- x 6950
Re: HELP, Citroen seatbelt sensor
No, you can't disable the warnings. You have cut or damaged the sensor wire that detects whether the seat belt has been fastened.
You can't just put a generic ebay seatbelt on - you really need the correct type as originally fitted - whether from a donor vehicle or get it replaced properly by a dealer or decent garage. You will fail your MOT if the seatbelts are not properly fitted and working. Also be aware if you have seat belt pre-tensioners.....
