Stuck ignition lock.
- Huskyxantia
- Donor 2023
- My Cars: Past cars
Xsara Picasso 2019 to 2022 r.i.p
Xantia mk1&2 1.9D & 2.0Hdi
Peugeot 206 sw 1.4hdi
Other models
Skoda fabia,escort van,ford ka,Vauxhall astra g car & estate, Vauxhall corsa b, Suzuki swift
Escorts mk 1,2,3,4,5 fiestas mk 1,2, Sierra diesel mk1 Mondeo mk1 diesel .
Peugeot 207 , 307sw
Now cars
Picasso 2.0Hdi now gone to scrappie
Citroen zx estate 1.9D the cherished one
Peugeot 206cc raised from the dead & saved from the crusher traded up to a 308cc
307sw traded for the 207 .
Wish list.
Peugeot 405 diesel
106 or 206
Mondeo Mk1 diesel once owned 1.8tdi was real nice. - x 429
Any ideas as to why i can't get my steering wheel ignition lock to come off can't turn the key ,nothing.
Was hot today could it be the reason its stuck on ?
Husky.
- Paul-R
- Donor 2023
- Lexia Available: Yes
- My Cars: 2015 1.6 Blue HDi 120 Peugeot 308 Active SW
2013 2.0 HDi 163 C5 Exclusive Tourer
2003 2.0 HDi 110 C5 Exclusive Estate (Gone)
2001 2.0 HDi 90 Xsara Estate (Gone) - x 1383
Re: Stuck ignition lock.
Is the steering under some tension? If the steering wheel is trying to return to a neutral position it can jam the plunger of the steering column lock. The cure it to turn the steering wheel slightly against the tension which will take the strain off the column lock and you should then be able to turn the key.
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
Agreed ^,
That usually happens when the car is parked for example against a curb with the wheels turned in, so prevents movement of the steering wheel to allow the unlocking. You sometimes need to have slight play in the wheel to unlock it.
- xantia_v6
- My Cars: -
1997 Citroen Xantia V6 (France)
1999 Citroen XM V6 ES9 (France)
2011 Peugeot 308 CC THP 155 (NZ)
1975 Jaguar XJ-S pre-HE (NZ) - x 835
If the key does not turn at all, it could be that one of the lock wafers has stuck in the wrong position. This can usually be fixed by vigorously inserting and removing the key a few times.
- Rp0thejester
- My Cars: C8 2.2 Hdi Exclusive
- x 808
If it was anyone else asking this question I'd do/say the above. But as it's you Husky something must be wrong!!
Champion of Where's CitroJim
- moizeau
- My Cars: 91 BX TZD Estate. Dead but loved
407 HDI 136 auto
C4 2l petrol coupé
2010 Dispatch III HDI 90
AND a 1980 Z1000ST
AND a 1983 GPz1100 inj
AND a 1995 Zephyr 1100
AND a 1980 Z650 (my moped) - x 317
Was the cabin fan on flat out the last time. It could be a molten ignition barrel if this is the ZX, though this normally occurs in the 'on' position when you try and turn the engine off.
Pete
- Huskyxantia
- Donor 2023
Other models
Peugeot 207 , 307sw
Now cars
Wish list.
Peugeot 405 diesel
106 or 206
Hi all , cheers for the tips, so ok this morning i took off the steering wheel surround gave me a better view of the whole ignition barrel , unclipped the 2 clips to the transponder receiver housing & moved this out the way then ,theres a weird screw with no head you have to undo,so screwdriver & hammer to carefully mark the screw on the edges then this moves the screw , repeated this 4 times to make 4 slots to tap the screw driver against this and it undid the screw , the screw then screws into a pin , with screw out of the pin ,knock the pin up the the whole barrel will then pull out ,
Ive now got free access to the disc that sits onto the barrel pin so i pop the key into the receiver turns off immobiliser use a screwdriver to start the car but remember to turn back 1 click cos no spring back then the starter isn't still energised hey presto car works , waiting to hear on a replacement, i didn't bother doing all the wiggle stuff as by the feel of it i could tell this morning the barrel had failed the heat hasn't helped . Once the new part gets here i can swap the barrel then swap the key blade that comes with it into my one , just means ill have to get another fob just to fit this original blade unto incase i need to unlock the doors manually , cars .. french .. because its french !
Husky.
- Huskyxantia
- Donor 2023
Other models
Peugeot 207 , 307sw
Now cars
Wish list.
Peugeot 405 diesel
106 or 206
- Huskyxantia
- Donor 2023
Other models
Peugeot 207 , 307sw
Now cars
Wish list.
Peugeot 405 diesel
106 or 206
Cheers mate, ive kinda got me some wheels again , all be it a dodgy way of starting the old girlRp0thejester wrote: ↑15 Jul 2022, 22:12 If it was anyone else asking this question I'd do/say the above. But as it's you Husky something must be wrong!!
Husky.
- Huskyxantia
- Donor 2023
Other models
Peugeot 207 , 307sw
Now cars
Wish list.
Peugeot 405 diesel
106 or 206
- Huskyxantia
- Donor 2023
Other models
Peugeot 207 , 307sw
Now cars
Wish list.
Peugeot 405 diesel
106 or 206
Husky.
- Huskyxantia
- Donor 2023
Other models
Peugeot 207 , 307sw
Now cars
Wish list.
Peugeot 405 diesel
106 or 206
Update, the brass pieces inside the lock have worn just spent 2 hours slowly taking the lock apart to be greeted with gunk mixed with grit, in the above video someone asks what screw driver is used to remove the 2 pins that release the casing into 2 sections.. there not screws there pins i tapped the smallest hex bit i had into the hole then twisted & turned as if i were unscrewing a screw & it slowly came out.
So my part is no good . I have sourced a complete ignition with keys ,driver door lock and petrol cap . I will have to switch key blades around change door lock & petrol cap then the key will work like nothing has ever happened.
Husky.
