Lexie installation problems
mtotterd
Hi,
I have been trying to install the lexia3 software but keep getting getting error
C\applic\lexia\calculo\four_004\syst_000\api_001\vers_227\\61997080.ulp
Error CRC
Does anyone know what this error means?
Or how I can move past the issue,
Thankyou in advance
Michael
Error CRC
Thankyou in advance
Michael
Med_tech3
Re: Lexie installation problems
I am having the same issue on windows xp service pack3. I uninstalled and reinstalled a few times with no success.
Did you get it working?
Huskyxantia
- x 909
Think it needs to be mounted on a virtual drive, dont ask me how , there should be some posts on here somewhere.
Husky.
- x 6945
You shouldn't need to install Lexia software separately at all if you are installing everything via the complete Diagbox software installation, as Both Peugeot Planet 2000 and Lexia software is already encapsulated within Diagbox, the main software programme. Diagbox will detect the vehicle type and launch the most appropriate version PP2000 or Lexia for circa 2007 and earlier vehicles and Diagbox for circa Post 2008 vehicles (but this will depend on Marque, model and year).
Also if any of you above have a failed DIAGBOX installation, uninstalling and reinstalling the software will make no difference. The software needs uninstalling and a cleaner programme needs to be run to remove all the folders and registry entries created which are left over from the uninstallation.
Huskyxantia
- x 909
I used to do the regedit through the command prompt , but you need to know all the file strings , bit long winded way
This looks handy as i might be using this soon.
https://www.wisecleaner.com/wise-progra ... aller.html
Husky.
Huskyxantia
- x 909
Well ive just wasted 3 hours of my life totally cleaned the laptop reinstalled software to be meet with this
Everything ive read for vm machines wont work it nags about 32bit not working with 64bit .. half the links on the net are dead
My software is for 32bit even trying the virtual way dint work
Husky.
Huskyxantia
- x 909
My bios is password protected so i cant even wipe it and reinstall a 32bit version of win xp, im just off now to play on the m25 ....
Husky.
- x 3296
If you can access the motherboard look for a jumper/switch marked "Clear CMOS" (or similar). If it exists move it to the other position, wait a few minutes, move it back, power up the system and see if you can get into the BIOS.
Huskyxantia
- x 909
This old laptop is like a brick in a tough case . This is doing my head in James , ive read everything and when i follow it its not working at all.
Husky.
- x 3296
What make/model of laptop?
Huskyxantia
- x 909
This ...
Husky.
Huskyxantia
- x 909
So its a rm ? Intel , which can effect the diagbox lexia stuff 160gbhdd 2gbram built like a brick out house, 64bit win xp pro sp3 ..
Husky.
- x 3296
Erm, the photos are not clear enough to read the labels.
Huskyxantia
- x 909
Sorry , here there are again.
Reason: Images rotated
Husky.
Huskyxantia
- x 909
My software came with a program that removes all of the diagbox installation if it goes wrong , it wipes the registry automatic, i went in reg edit on command.com everything to do with pp2000 lexia and so on was all gone , so i did a fresh install and it wont open just a blank square start up screen
Husky.
