Expert 1.9 2003 Timing belt snap/ replaced the engine won't start
TOM735
Re: Expert 1.9 2003 Timing belt snap/ replaced the engine won't start
Unread post by TOM735 »
Hi again
I have replaced the Advance Actuators Solenoids Valve, was easy.
Engine starts but is struggling to start.
Have look on video.
When the engine is hot starts easier.
I still haven’t sorted this problem, where I have look next?!
Glow plugs? Engine was worm and was worm outside
https://youtube.com/shorts/jltTr67I1RU?feature=share
x 1240
Unread post by Peter.N. »
Sounds like either low compression or retarded pump timing. A compression test might be the easiest to try first.
TOM735
I have to give up.
Does anybody know the garage in Surrey where they have the knowledge about this engine?
I’m base in Leatherhead
