- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5721
Here you go:
Rear Sliding Door Motoreducer Rear Sliding Door Rear Sliding Door Control
- My Cars: C4 PICASSO GRAND BLUEHDI EXCLUSIVE PLUS
hi can you help me with ecu part number for this
vin number is VF3**************[VIN obfuscated, can be read by forum staff]
and if the is equivalent numbers that will go with this model
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
@malawiboy1 : Which ECU are you talking about? Engine ECU, BSI, ESP / ABS ECU, there are at least 20 ECUs on the vehicle.
For now, I'll assume you mean the Engine ECU
Item (1), Part: 1608291280, price £1413.36 inc. VAT from Citroen, brand new. This is the only PSA part number for your vehicle.
- My Cars: Citroen C4 Picasso Exclusive 2014
Hi Ya,
Would it be possible to get the part number and if possible the engine code and transmission type for the following parts please:
Vehicle C4 Picasso 2014 1.6 Hdi
Parts:
Clutch
Rear Pads & Disc
Timing & Auxiliary Belts
Man Thanks
Zane
Parts:
Clutch
Rear Pads & Disc
Man Thanks
Zane
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Already have it Richard
@zane2g2: (If this is for your VIN ending 017):
Clutch Kit
Item (1) OEM New Clutch Part: 1610211580, £553.13
OEM Exchange Clutch Kit, Part: 1610212980, £289.90
Rear Brakes
Discs
Item (1)
OEM Disc kit, Part: 1609582880, £116.82
Pads
Item (2)
OEM Pads, Part: 1636413980, £95.93
OEM Cheaper Pads, Part: 1619790880, £63.49
Timing
You have several options:
OEM Belt only item (5), Part: 1608745980, £124.48
OEM Original Timing Kit Item (6) that includes the Belt and the tensioning and retractor rollers (3) & (4), Part: 1608747480, £171.02
Or as above, but cheaper kit alternative, Part: 1635067180, £115.45
Or
Full OEM Kit that includes the belt, tensioning rollers and the water pump Item (15) Part: 1613561980, £254.88
Cheaper Full Kit, Part: 1684891780, £163.64
Alternator Belt
Item (20), Part: 5750ZQ, £60.76
Clutch Kit
Rear Brakes
Discs
Item (1)
Pads
Item (2)
Timing
Or
Alternator Belt
Spot on Marc,
Many thanks for you and your teams help
Cheers
Zane
Cheers
Zane
thanks youGiveMeABreak wrote: ↑27 Jun 2022, 21:51 @malawiboy1 : Which ECU are you talking about? Engine ECU, BSI, ESP / ABS ECU, there are at least 20 ECUs on the vehicle.
the engine ECU
the one you have got but is other equivalent numbers that will work on the same model?
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
That’s the official part number for this engine ECU. Each ECU is designed for a specific engine.
You can search on this number and as long as this number is returned in the results and you have checked with the seller that the number I provided is compatible, you should have the correct one.
- My Cars: Peugeot 406 2.0 HDi 110
Hi guys.
Part number for fuel lift pump and the accompanying lock ring please.
VIN VF3**************[VIN obfuscated, can be read by forum staff]
Many, many thanks!
Many, many thanks!
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
@pugpirate:
Item (2) Fuel Pump, Part: 1607401880, £363.37
or Part: 1607402080, £363.37
Item (4) Fuel Gauge Seal. Part: 153124, £9.98
Item (5) Fuel Tank Ring, Part: 153120, £4.68
All available direct from Peugeot VAT inclusive.
- My Cars: DS DS5 2.0 180BHP Prestige 2016
Citroen Berlingo Multispace 1.6 90BHP XTR 2014
Both in black, we could start an economy brand undertakers - x 45
Can you please let me know the part code(s) for the ancillary drive belt kit, for a DS5 2.0 180BHP, VIN VF7**************[VIN obfuscated, can be read by forum staff] ?
It needs a kit/set for its 6th birthday (even though mileage only 68k), I guess this means belt plus tensioner(s) and pulley(s). It has climate control and start-stop.
Thanks very much.
Thanks very much.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
@NotAnInterestingName:
Item (10) Belt, Part: 9805463680, £62.72
Item (3), Dynamic Tensioner Roller, Part: 1611426480, £130.66
Item (4), Dynamic Tensioner Roller, Part: 1616876780, £127.22
- Donor 2023
- Lexia Available: Yes
- My Cars: C5 X7 2009 2.0 HDI VF7**************[VIN obfuscated, can be read by forum staff]
C4 2010 2.0 HDi Exclusive VF7**************[VIN obfuscated, can be read by forum staff] - x 378
Is it possible to get conformation of a super seeded part number that i have been given from my local dealers.
It is for my C4 vin in my sig
I originally ordered part 1675689680
However my dealer has given me part 9837728580.
before i send it in for work to be done i just want to double check it is the right part.
Colin
Colin
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
1675689680 is the Gearbox Lip Seal (right) 32 x 50 -10.
The original part number is 312165, now superseded by part 1675689680.
Part: 9837728580 does not come up for this vehicle on Citroen parts for this or any other vehicle. So I would certainly reject it as it matches neither of the parts on the current live database. Unless this is an unbranded third part part, but that's not what you ordered....
- Donor 2023
Thanks Marc maybe i have got wrong part number but if this works the picture is what i have been given, i did post in another thread earlier and do not want to double post but gut says it is the wrong part.
Thanks Xantia V6
Thanks Xantia V6
