C4 picasso 1.6 bluehdi - 96k/6 year service. What's required please?
Mexico14
Unread post by Mexico14 »
What is required on the 96k/6 year service please. Is there any info available that states what is needed at each service?
x 6955
Re: C4 picasso 1.6 bluehdi - 96k/6 year service. What's required please?
All the service operations are stated in your vehicle maintenance booklet, including what is done and at which service, but the following will be due for this mileage and age:
  • Checking Particle Filter for clogging
  • Check the Coolant PH level
  • Replacement of Air Filter
  • Check DPF Additive level
  • Filling of Adblue Reservoir
  • Replacement of Diesel Fuel Filter
  • Replacement of Brake Fluid
  • Replacement of Cabin Filter
  • Replacement of Ancillary Drive Belt
x 1484
The service book for ours doesn't give the schedule, I had to login to / sign up to Citroen and download the schedule:
Reason: Image rotated
Mexico14
GiveMeABreak wrote: 24 Jun 2022, 10:59 All the service operations are stated in your vehicle maintenance booklet, including what is done and at which service, but the following will be due for this mileage and age:
There's no mention of what's needed in my booklet, not sure why they omitted it.
Is that 100% what's needed for my car as a local garage checked on their system and they said it only needs oil and filter + brake fluid - I thought it may have needed more than only that!
What is required at the 112k service please?
x 1484
Er..see my post above? If you click on it it will enlarge and only be sideways :lol: cam belt is due at 112k
x 6955
Mexico14 wrote: 24 Jun 2022, 16:49
These are the specific items that will need doing according to the age and mileage as stated for your car.
Richard has given you a list of the general main operations and when they need carrying out by age or mileage. The bullet list I provided you with is for your vehicle and 96k miles and 6 years as you stated.
So for example the brake fluid needs changing every 2 years, so that is something that would need doing at 6 years.
