Hi there!
I have a DS5 with electric sunblind roof. It happened that one day, none of them works. More to say, the buttons doesn't have any light, nor make any sound when pressed. Looks like dead fuse to me, but can't seem to find any info about it. My manual doesn't have refference to any roof fuse, and in the official support only points me to garaje and pray.
If any1 have any info, will make my day!
Thanx!
DS5 Cockpit Glass Electric Roof Fuse
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5723
Re: DS5 Cockpit Glass Electric Roof Fuse
Ok, so the blinds are referred to as 'Vellum' and each has a fuse controlling them.
There are 3 fuses, all in the BFH3 fuse box and I assume you have a left hand drive being in Spain.
This is where the particular fusebox is located - they are referring to specific harnesses in the diagram, but where these plug in is the BFH3
These are the fuses for each:
F8 30A Rear Vellum
F15 30A Front RH Vellum
F16 30A Front LH Vellum
F8 30A Rear Vellum
Whoa!
Very nice info. I'll open the box compartment and check them out. As i can see, there are no more 30A fuses in that box, so i guess they will be pretty straight up to locate.
Thank you very much!
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
No worries, but I suggest you follow the BSI Reset / Battery Disconnect / Reconnect Procedure if disconnecting the battery - which is recommended before changing fuses to avoid any problems.
