Huskyxantia
x 896
Unread post by Huskyxantia »
Yes it has ac, reg is kn02 vkj many thanks
:-D
x 1056
Unread post by wheeler »
The part I listed above is the correct one.
Was originally 575196
x 6955
Yes, VIN please for the specific vehicle please. This avoids incorrect parts.
Huskyxantia
x 896
Sorry just had the chance now to check the vin
Hope that jelps
:-D
eurofjr
(Donor 2022)
x 4
Unread post by eurofjr »
Hi Marc,
What is the PN for the auxiliary/serpentine belt?
VIN VF7**************[VIN obfuscated, can be read by forum staff]
Best,
Jim.
x 6955
Huskyxantia wrote: 16 Jun 2022, 13:03 Sorry just had the chance now to check the vin
Hope that jelps
Item (6) Part: 1613838480, £60.41 direct from Peugeot.
x 6955
eurofjr wrote: 16 Jun 2022, 14:21 Hi Marc,
Best,
Jim.
Item (20), part: 9803580580, £34.09 direct from Citroen. VAT inclusive.
x 6955
This thread was setup for staff to provide subscribing members with parts info and as such I just respond to the requests as I get notified, and don't have time to read all the in between stuff - and as per post one, this thread is strictly moderated to keep the requests and answers as succinct as possible. :wink:
x 1066
Unread post by Rp0thejester »
I'd like to know what dpf fluid I need for my C8. VIN VF7**************[VIN obfuscated, can be read by forum staff]. It has green buttons/tabs if that helps narrow it down.
Huskyxantia
x 896
Eolys 176
:-D
x 6955
Rp0thejester wrote: 18 Jun 2022, 19:30 I'd like to know what dpf fluid I need for my C8. VIN VF7**************[VIN obfuscated, can be read by forum staff]. It has green buttons/tabs if that helps narrow it down.
Your build date is 10783, therefore you need Eolys 176. Your click-fit connector may be green or white, but Eolys 176 is the correct additive for the build date.
It's very important to check exactly from the VIN as the C8 covered quite a production span and different fluids were used (DPX42 for the first generation and Powerflex for the last generation), with Eolys 176 in the middle.
x 1066
I knew it wouldn't be a simple that's the one, it does have a Citroen badge after all.... :)
Huskyxantia
x 896
GiveMeABreak wrote: 19 Jun 2022, 09:24
Rp0thejester wrote: 18 Jun 2022, 19:30 I'd like to know what dpf fluid I need for my C8. VIN VF7**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]. It has green buttons/tabs if that helps narrow it down.
I was just looking to confirm my door post sticker for the build date 10783 .. cheers marc, never known so many fluids !
:-D
parnell
(Donor 2022)
x 12
Unread post by parnell »
Hello , can someone please provide part numbers for parts 6 , 7 & 8 for a 2012 Citroen 165 2.0 diesel ? Many thanks.
x 6955
I assume this is for your C8 VIN ending 238? If so, there is no item 8, so again I'm assuming you mean item (5)...
That being the case:
Item (5) Assembly Part: 214907, £5.75
Item (6) Assembly Part: 214908, £6.05
Item (7) Declutching spring Part: 214898, £11.21
