Huskyxantia
- x 888
Yes it has ac, reg is kn02 vkj many thanks
Husky.
- x 1056
The part I listed above is the correct one.
Was originally 575196
- x 6955
Yes, VIN please for the specific vehicle please. This avoids incorrect parts.
Huskyxantia
- x 888
Sorry just had the chance now to check the vin
Hope that jelps
Hope that jelps
Husky.
eurofjr
- x 4
Hi Marc,
What is the PN for the auxiliary/serpentine belt?
VIN VF7**************[VIN obfuscated, can be read by forum staff]
Best,
Jim.
Best,
Jim.
- x 6955
Item (6) Part: 1613838480, £60.41 direct from Peugeot.Huskyxantia wrote: 16 Jun 2022, 13:03 Sorry just had the chance now to check the vin
Hope that jelps
- x 6955
Item (20), part: 9803580580, £34.09 direct from Citroen. VAT inclusive.eurofjr wrote: 16 Jun 2022, 14:21 Hi Marc,
Best,
Jim.
- x 6955
This thread was setup for staff to provide subscribing members with parts info and as such I just respond to the requests as I get notified, and don't have time to read all the in between stuff - and as per post one, this thread is strictly moderated to keep the requests and answers as succinct as possible.
- x 1065
I'd like to know what dpf fluid I need for my C8. VIN VF7**************[VIN obfuscated, can be read by forum staff]. It has green buttons/tabs if that helps narrow it down.
Champion of Where's CitroJim
Huskyxantia
- x 888
Eolys 176
Husky.
- x 6955
Your build date is 10783, therefore you need Eolys 176. Your click-fit connector may be green or white, but Eolys 176 is the correct additive for the build date.Rp0thejester wrote: 18 Jun 2022, 19:30 I'd like to know what dpf fluid I need for my C8. VIN VF7**************[VIN obfuscated, can be read by forum staff]. It has green buttons/tabs if that helps narrow it down.
It's very important to check exactly from the VIN as the C8 covered quite a production span and different fluids were used (DPX42 for the first generation and Powerflex for the last generation), with Eolys 176 in the middle.
- x 1065
I knew it wouldn't be a simple that's the one, it does have a Citroen badge after all....
Huskyxantia
- x 888
I was just looking to confirm my door post sticker for the build date 10783 .. cheers marc, never known so many fluids !GiveMeABreak wrote: 19 Jun 2022, 09:24Your build date is 10783, therefore you need Eolys 176. Your click-fit connector may be green or white, but Eolys 176 is the correct additive for the build date.Rp0thejester wrote: 18 Jun 2022, 19:30 I'd like to know what dpf fluid I need for my C8. VIN VF7**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]. It has green buttons/tabs if that helps narrow it down.
Husky.
Onlineparnell
- x 11
Hello , can someone please provide part numbers for parts 6 , 7 & 8 for a 2012 Citroen 165 2.0 diesel ? Many thanks.
- x 6955
I assume this is for your C8 VIN ending 238? If so, there is no item 8, so again I'm assuming you mean item (5)...
That being the case:
Item (5) Assembly Part: 214907, £5.75
Item (6) Assembly Part: 214908, £6.05
Item (7) Declutching spring Part: 214898, £11.21
