Please help!
I have a Citroen Xsara Picasso Desire 1.6 petrol 55plate which misfires and has a fault code P1336 (crankshaft sensor)
I can’t find the sensor on my vehicle and there seems to be a few different models online but can’t find my exact one.
Does anyone know the exact location of the sensor and what it looks like (it’s not by the crankshaft pulley)
Any info on this specific model would be appreciated
Crankshaft sensor
- My Cars: Citroen Xsara Picasso
Re: Crankshaft sensor
The crank sensor is on the flywheel end on this engine. Its underneath the thermostat housing so can be difficult to see.
Number 6 in the picture.
Thanks wheeler you was spot on. Found it straight away and got it out. Will let you know if it works when I fit the new one
Hello, If the new sensor is a Bosch and it doesn't cure the problem it may be the sensor wiring, hopefully it will work, mine didn't till i did a bit of rewiring. Video from Citroenguy on my post car not starting.
Citroen GSA flat4 engine written off
Citroen BX 1.4 gone
Citroen BX 1.6 gone
Citroen Xantia 1.8 gone
Citroen Xantia 1.8 still living now 148 k
Citroen BX 1.4 gone
Citroen BX 1.6 gone
