x 6950
Assuming you have replaced it with the exact same engine then it will be fine.
Item (9) is unfortunately no longer available :( - which is probably why it has been badly bodged. If they have connected the pipes together then of course it is going to leak with pressure build up.
You may need to try and get some pipe made up or modify a similar pipe.
The original part was: 1180K9.
x 1083
Unread post by Rp0thejester »
Ah, that explains it, thx for the info. So nowhere does that hose?
x 3298
As the part is no longer available it could be worth calling into Pirtek with (if it can be safely removed) that item 9 pipe, to see if they could make up a replacement. You don't have much to loose, and a safely working engine to gain.
x 1083
That's exactly what I was thinking!! Pirtek or any other hydraulic hose company. I've destroyed many a hose on a Brokk
x 1083
Thx for the info Marc, that was what I was expecting. My garage told me the brake pipe lines aren't available, is that correct??
x 6950
Rp0thejester wrote: 04 Jun 2022, 18:50 Ah, that explains it, thx for the info. So nowhere does that hose?
Officially no - they have stopped making that part now as the car is over 16 years old. It really depends on what the part is and the demand.
I forgot to mention the dimensions for you:
DIAM 12X16 LONG 245
x 1083
Thx that will help alot, so the internal diameter is 12mm?
x 6950
Rp0thejester wrote: 04 Jun 2022, 19:03 Thx for the info Marc, that was what I was expecting. My garage told me the brake pipe lines aren't available, is that correct??
Again, it depends on which pipes you need - some are and some aren't:
Available: 1, 2, 7, 8, 9, 10, 11, 14, 15,
Unavailable: 5, 6, 12, 13
x 6950
Rp0thejester wrote: 04 Jun 2022, 19:09 Thx that will help alot, so the internal diameter is 12mm?
Yes :wink:
x 1083
I know it's a stupid question, but I'm a diamond/core driller. The amount of times I'm told internal dimensions rather than the external dimensions...
x 3298
Rp0thejester wrote: 04 Jun 2022, 19:15 I know it's a stupid question, but I'm a diamond/core driller. The amount of times I'm told internal dimensions rather than the external dimensions...
One of my (myriad of) sayings is "There is no such thing as a stupid question". If you don't have the information you require you have to enquire.
x 1083
Great anology, my fav is Fail to plan Plan to fail. But I always say to anyone, if you don't know ASK! Nothing worse than them get it wrong!! If you don't know ASK!!! It takes a real man to ask for help, kids struggle
x 3298
Rp0thejester wrote: 04 Jun 2022, 19:37 Great anology, my fav is Fail to plan Plan to fail. But I always say to anyone, if you don't know ASK! Nothing worse than them get it wrong!! If you don't know ASK!!! It takes a real man to ask for help, kids struggle
I have an addendum to that saying; "...but stupid, avoidable mistakes do exist".
jamescarruthers
x 47
Unread post by jamescarruthers »
GiveMeABreak wrote: 04 Jun 2022, 17:23
jamescarruthers wrote: 04 Jun 2022, 16:43 Hello all. My sister has managed to loose the fuel filler cap for her 2001 2.2 C5… it’s the magnetic type that tells the car to inject Eolys fluid so I’d better get it replaced pronto!
Can I have the part number, please, and is it still available to buy from Citroen? If not I’ll get a second hand one.
James, if this is for your VIN ending 665, then there were 2 options - a locking cap and a non-locking cap:
(6) Locking
Combination specified on order, part: 1508J4, £72.88
Random Combination, part: 1508J3, £101.77
(10) Non-locking was part: 1508F7, £19.09, but no longer available.
Thanks very much. Got a second hand on the way now. Cheers.
1987 Volvo 480 ES
2006 Citroen C6 3.0 petrol Exclusive
Armidillo
(Donor 2022)
x 274
Unread post by Armidillo »
Hi all
I have a D9 406 SV, VIN VF3**************[VIN obfuscated, can be read by forum staff], which is currently refusing to start. The starter no longer spins - best I was able to get was a very weak part-turn. This has been brewing for a while, but at first it was just occasionally, and after a few retries it would suddenly just work.
It is definitely not the battery - it's showing 12.7 volts. Just to be sure I connected jumper leads from a running vehicle - measured voltage at 13.8v - no difference.
Now I realise that there are other possibilities, but is 438087 the right starter motor? Looks like Spareto could fly one out to me for about $100 less than I could buy one in Australia.
Cheers
Alec
