Peugeot 308SW T7 - are these sensor values normal?
Post your Cit/Peu/Ren air conditioning queries or advice.
icu12345
Unread post by icu12345 »
So I've got a 2010 Peugeot 308 T7 and the A/C stopped working. The compressor doesn't kick in. The system must be full of refrigerant because I had it serviced two weeks ago and there are no visible signs of leaks (the a/c oil has a UV dye in it but I couldn't identify any leaks).
I noticed the following very peculiar live data:
The car has a two-zone AC control. So I find it very implausible that the sensors are dead on both sides. There are no further DTCs.
Could this be a reason for the compressor to not kick in?
Where are these sensors physically located?
Thanks in advance :)
PS.: I have also uploaded the live data from the BSI - would be grateful for any troubleshooting tips.
x 1496
Re: Peugeot 308SW T7 - are these sensor values normal?
Looks like the low pressure switch is activated. Either there's not enough gas in it, it the switch is faulty.
icu12345
Thank you for the insight. I must've missed the "low pressure safety". However, as if missing the line in the live data wasn't embarrassing enough, I can't seem to locate a sensor on the low pressure line. There is one 3-wire-sensor on the thinner line but this must be the high pressure switch. So where should I look for the low pressure sensor and is there one at all? There is nothing on the condenser as well. The car is a 2010 Peugeot 308 2.0 HDI.
