Is there a difference on the exhausts fitted to left and right hand drive Xsara Picasso's? Mine is a right hand drive registered for use in Spain ( it was cheaper than buying a new car!) Now the exhaust middle box has developed a blow. I took it to a local tyre and exhaust shop who advertise on their website a middle section for 133€ plus 30€ fitting, only when I got there they told me it was 300€ for the exhaust because its different for a right hand drive!
Exhausts on a Xsara Picasso
Brian60
- x 3
Just a quickie.
Advice appreciated, I could drive it back to the UK for that money and have it done there, well maybe not now considering the price of petrol
- x 1506
Brian60
- x 3
Re: Exhausts on a Xsara Picasso
Sorry should have added that info........1.6 petrol 16 valve
- x 1061
There is no difference in the exhaust between RHD & LHD on this car.
Brian60
- x 3
Just a quick update on this. Although there does not appear visually to be any difference at all between r and l hand drive. I have been to 4 shops to have it replaced, all of them pulled out their ordering sheets and everyone of them had a different part number for the two exhausts! The only difference being the price, LHD was 127euro + fittting charge, the RHD equivalent was 300euro + fitting charge! I eventually had it replaced by an English mechanic in a nearby town, who offered to order the LHD, try it and return it if it didn't fit - he made it fit and recharged my aircon for 200€.
- x 1955
That implies that there was something that stopped the exhaust from fitting straight away. Any idea what he had to do to get it to fit?Brian60 wrote: 05 Jun 2022, 14:18I eventually had it replaced by an English mechanic ... LHD ... he made it fit ...
- x 1061
The Citroen parts database does not offer any option of choosing RHD or LHD if you select without a VIN filter suggesting they are both the same part number?
I really cant think what could be different about the exhausts apart from maybe the down pipe as it passed over the steering rack?? you were needing the middle section though.
I often find with cheap aftermarket exhausts you need to 'tweak' them to fit a lot of the time.
