What DS5 Head Unit is this?
NotAnInterestingName
- x 51
Re: What DS5 Head Unit is this?
So is what you call "Touchscreen" a specific model?
To me it's a descriptive word, not a model name.
- x 6945
PSA use it as both. I am using it as the name of the system shortened to 7" Touchscreen as that is what they refer to it as (7" Touchscreen Tablet). If I am referring to the Connected NAV (NAC / RCC) units I'll use Connected Nav / NAC
Connected NAV
Connected NAV
Ceenine
- x 17
Sorry to resurrect an old post, but I am interested to know some technical data in relation to the audio section of the telematics on my late 2015 DS4 Crossback. I believe you refer to it as NAC being the touchscreen unit with the reversing camera. The unit seems to be better than the RT6 unit in my C5 which has a Philips amplifier as part of original supply for the car. In particular I am interested to know what the power of the NAC audio unit is (eg watts RMS per channel). It really is a good little unit. Maybe the impressive quality of it relates to (assisted by) the aftermarket speakers installed. No, they aren’t Focals unfortunately as I was too late getting onto that “special” marketed by PSA.
- x 6945
Hi Don. You don't have the Connected NAC or NAV unit, you have the SMEG (nothing to do with the Italian Domestic Appliance manufacturer
) 7" Touchscreen fitted, which is the top picture.
These have 'customer-friendly' names as well as internal names used by PSA at the time. I only referred to the more commonly used name used in the owner handbook, to avoid introducing another layer of confusion. But there were several incarnations of the 'SMEG' system with later versions supporting Apple CarPlay / Android Apps.
PSA don't supply internal data for the units, only the connections and functionality of the units, but they were the replacement to the RT6 and have now been superseded by the RCC (without navigation) / NAC (with navigation) systems from at least 2017 to date.
Only some SMEG 7" touchscreen units were fitted to the last run of the C5 X7s before they ceased production, but the Connected NAC system was never fitted.
Ceenine
- x 17
Thanks Marc, that tells me that the C5 for sale in Australia and described as “Finale” most likely has the Smeg unit similar/same as my Crossback.
I admit that wanting technical data was a big ask. Considering that my wife doesn’t allow me to take advantage of the relatively small amount of watts available in the Crossback, it is somewhat academic. At domestically permissible levels it is a satisfactory unit at the end of the day.
Your detailed response is appreciated as always.
Don
Don
- x 1939
I think it's actually the SMEG+, or possibly even the SMEG+ IV2, unit that was fitted. The SMEGs, whilst similar, were an earlier unit.
earlam
Re: What DS5 Head Unit is this and
What unit is mine anyone and is there an alternative android replacement
- x 1939
That looks like an RT6 unit to me. No idea about Android replacements though.
robdevil
- x 8
It is rt6. Read this post: viewtopic.php?t=69891#p701654earlam wrote: 14 Jan 2024, 21:53 What unit is mine anyone and is there an alternative android replacement
Peppazot
I'm so glad i found this postNotAnInterestingName wrote: 11 May 2022, 13:25 Hello. I'm just about to enter the world of DS5 ownership, all very exciting. I understand there were various different head units at different times, I wondered if someone here would know what unit it was from a blurry photo (attached)? Sorry, it's the best I have at the moment.
I've ordered it but haven't collected it yet, I'm looking at what sat nav update options there are. It's a 2016 DS-brand DS5 Prestige 2.0 HDi Auto Stop/Start. It doesn't have the dial and buttons by the handbrake that I've seen on earlier models, just a little sweetie tub instead.
Many thanks.
I have only just purchased my first DS around 4 weeks ago, a 2015 (65 Plate) Blue HDI 180 DS5 Auto. I'm in a current love/hate relationship with it due to a few issues which the garage have hopefully now sorted
Just wanted to see regarding sound upgrade if anyone had done this yet and also as you said if we can get updates for the system easy enough?
- x 6945
Hi
Mirrorlink is more or less discontinued now.
Most manufacturers have withdrawn support now including Samsung. Basically if you have the old Mirror Link App on your compatible phone it may continue to work until the App is removed from your phone, then it's gone for good as it is no longer available to install.
If you have a Touchscreen system in your DS5 than it is very likely to be the SMEG system. I can confirm with your VIN. Please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff.
Peppazot
Thanks Marc, appreciate the replyGiveMeABreak wrote: 01 Mar 2024, 16:35 Hi
My VIN is - VF7**************[VIN obfuscated, can be read by forum staff]
- x 6945
Ok, so confirmed you have the SMEG Digital Receiver unit fitted. Bluetooth streaming is never going to be as good because it doesn't support lossless. Although this isn't an issue for most people on the go in the car to be honest.
Make sure the Head Unit firmware is up to date, as updated firmware provides for later Bluetooth protocols and may address some issues.
Peppazot
Thanks Marc for the info, much appreciatedGiveMeABreak wrote: 04 Mar 2024, 10:51 Ok, so confirmed you have the SMEG Digital Receiver unit fitted. Bluetooth streaming is never going to be as good because it doesn't support lossless. Although this isn't an issue for most people on the go in the car to be honest.
- x 6945
Ok, but be mindful they may charge you diagnostic time to do this.
