Hello,
I have a flashing interior orange light whenever I turn sidelights or headlights on. Its an ambient light that illuminates the small storage area below the heating controls. It will illuminate dim but then flash on and off brighter at 1 second intervals as soon as I turn the exterior lights on, dims and stops flashing again when I turn them off.
All exterior lights are working, any thoughts on what it might be? It's rather annoying driving at night.
Blinking Interior ambient light
Re: Blinking Interior ambient light
Just to add, if I have the interior dashboarr light brightness on the lowest setting when exterior lights are on, the blinking stops (the light stays on solid), however as soon as I notch the brightness up it'll blink on full brightness).
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5721
It's certainly not designed to flash as that would be a distraction. I suspect it is failing or faulty.
- My Cars: Citroen DS3 1.6THP 2015
Hello, I am having the same problem.
The strange thing is that the blinking is regular in 1 second cycles.
I don't think this would happen with just a broken bulb or bad contact.
Or does anyone know the part number to replace it?
I think it is 6362AE, but there is too little information.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
That is the ambience lamp, but it's a complete module, so there is no bulb and needs to be replaced as a whole module. It's not cheap either at just under UK £90!
