MyWay Issues
This unit is the MyWay system, also referred to as RNEG, made by Harman Becker.
Main Features: Also referred to as RNEG, the MyWay colour satellite navigation system, has SD card, integrated European mapping, live trafic information, voice guidance and graphics in 2D or aerial perspective & it features a Bluetooth® system (Bluetooth phone compatibility only - no Bluetooth Audio Streaming).
kisst-1
Re: MyWay Issues
Unread post by kisst-1 »
I encountered an obstacle. Can you help me where to find the micro sd card in this headunit?
x 6963
Re: MyWay Issues
OK, so we need to rewind a bit here - I've been dealing with similar topics with other members over the last few days and multiple other topics so it gets a bit confusing in the overlap. Of course as you initially posted in the wrong Forum section (RT6 instead of MyWay Forum) it it getting confusing trying to remember your system without re-reading everything again. So I have moved this topic into the MyWay section now.
So of course I was still thinking in RT6 terms when I last responded - but of course the MyWay does not have an internal Micro-SD card at all it has onboard EEPROM flash memory, so there isn't anything you can do regarding swapping parts, sorry!
The only solutions I have seen, short of replacing the unit or sending it off for repair is 're-animating' the system which needs equipment to attach to the motherboard and software which I don't have.
Some bloke was doing the operation as shown here, but he hasn't responded to questions...
Another video showing the tool for Harman Becker systems:
kisst-1
Re: MyWay Issues
I've already figured out that this can only be a motherboard integrated. ](*,)
kisst-1
Re: MyWay Issues
There’s a car hifi mechanic who would have undertaken it, probably doing the same re-animating, it would only cost a lot.
I will try a more professional service to see if they can at least fix the BSI configuration.
As a last resort, the car hifi mechanic remained.
Tank you for your help Marc
x 6963
Re: MyWay Issues
I know the repairs are expensive - even with Clarion, so good luck.
