Hi our peugeot partner 1.6 hdi 2016 is going in to limp mode constantly with the following codes stored.
1. p2541 Fuel pressure in low pressure circuit present. Voltage too low.
2. p008a Low pressure fuel circuit. Fuel pressure lower than the reference value.
3. p00ba Low pressure fuel circuit. Fuel pressure lower than the reference value.
Changed fuel filter assembly complete also changed low pressure pump in tank still the same still starts and drives fine but bleeps constantly engine fault then limp anyone advise where to go next?
Many thanks
Stephen
Peugeot Partner 1.6 hdi 2016 Fault
Indygo1987
- New User
Re: Peugeot Partner 1.6 hdi 2016 Fault
Did you get to the bottom of this issue I have exactly the same faults.
Kind regards dean.
Kind regards dean.
iso
- New User
hello, i have the same 3 fault codes, replace the low fuel pressure sensor 2time. but after 5000km comes back.
p2541
p008a
p00ba
what is your solution for this and your car fixed problem
p2541
p008a
p00ba
Sime28100
- New User
2018 Expert van We had same issue. Replaced low pressure sensor and ok for a week or 2. Same fault occurred. Replaced in tank pump and ok for a week or 2. Same fault reappeared. Finally found bad wire to the low pressure sensor. When viewing live data on the scan tool you could see the pressure dropping out when you moved the wires.
DamoBarnes
I have the same problem on my van with the same fault codes logged. Where abouts was the broken wire?
Cheers
Cheers
mark_french1991
- New User
I have the exact same fault codes mate and it’s been happening for year now no one can get to the bottom of it.
Did you find out where the faulty wire was ?
- x 1908
Regrettably, Sime28100 hasn't been back to this site since the day he/she posted above, Sat Oct 08.
In fact all the one time posters above haven't been back since their singleton posts
FulvioM8
- New User
Recently got the same problem and the fix has worked so far.
Peugeot Partner with 1.6 BlueHDI from 2017, same error codes as OP.
In my case it was the connector to the low pressure sensor: one of the pins shorted out, leading to a faulty connector and a shorted sensor.
I've replaced both the low pressure sensor (located in the back of the engine, near the ignition pump) and its 4-pin connector, so far so good.
Muttly
Hi, I dont suppose you have a picture of the location for the faulty sensor? Thanks, Dov
mr_builder
expert 2017 van same problem, can't find location of the low pressure fuel sensor, can anyone help? thank you
MMichael
- New User
Did somebody fix this this Problem? I habe the same Problem and indont habe the answer. The CR sensor ist new.
