x 6953
Re: Citroen and Peugeot Official Parts Requests
Ohfishalee wrote: 21 Apr 2022, 19:40 Hello. I am looking for the part in the image below which sits above the original clock display. You can see the clock (original part) in the background of the person's hand.
[it is a modifed clock display. unsure if it is a stock item from another model Peugeot/Citroen]:
Image[/img]
That doesn't look like the correct stock faceplate, so can't help you if it's not an official part. I've checked without filters and there are no parts supplied for other telematics / display systems that are of the larger type, so this may well be a replacement for an aftermarket unit.
This is your faceplate:
Your faceplate as shown in the diagram Item (3), part: 8211N9, £70.54 from Peugeot.
moizeau
x 429
Unread post by moizeau »
Morning, The lad I've helped before with his Boxer / Relay (unsure which) is having more problems. There is a water block at the front of the engine that is cracked and he needs to get a replacement.
The vin is available on this post
https://www.frenchcarforum.co.uk/forum/ ... hp?t=69777
Is the part number shown in the photos a recognised PSA P no. so he can use that to track one down please?
Thanks very much
Pete
x 6953
9643212080 is the part number Pete. This is for the water Outlet tank, no longer available from PSA, which had the original part number of 1336 V4.
A quick search finds a new one here for £74.99:
https://www.ebay.co.uk/itm/363133741875 ... 9be4d3d5c4
moizeau
x 429
Thanks very much Marc, much appreciated
Pete
Xantianut
x 122
Unread post by Xantianut »
Ay up!
We have some creative thieving little scrotes round here!! I am missing both the bolts that secure the rear of the front bumper on my C5 LY52MXO. It's also missing 2 Torx bolts above the grille so may as well get them while I'm at it!
What fixings do I need? Goooooooogling only finds the plastic rivets. And I got loads of them!
x 6953
@ Xantianut: Please see the first post: viewtopic.php?p=685750#p685750
Xantianut
x 122
Thanks, Marc!!
RIP
BX16TRS (x2) (Fifi 4 and 5)
BX19DTR (Fifi 2)
BX14E (x2) (Fifi 1 and 3)
gouldie
(Donor 2022)
DS5 power steering pipes
Unread post by gouldie »
Hi just wondering if someone could help me with the power steering pipes part number. One of them has a split in the needs changing.
I'm thinking there the same as my c4gp 2 but want to double check
Thanks in advance
Rich
Reason: Moved to Official Citroen Peugeot Parts Requests
x 6953
@gouldie: If it's the High Pressure Steering pipe shown at (1), then it is part 4014SN (for your vehicle, VIN ending 829).
Priced at £188.18 inc. VAT direct from Citroen.
The C4 Picasso MK II (B78) doesn't have any power steering pipes - it uses an electric Power steering system.
The C4 Picasso MK I only used the same part number on models from a specific build date (10 December 2010) on specific engines.
gouldie
(Donor 2022)
Hi no it's the return hose that's leaking do you have the part number for that one? Thanks
x 6953
That's the only part listed as you can see from the diagram, and no other part number shown, so they possibly come as one set. Best to check with the dealer's part department for confirmation.
gouldie
(Donor 2022)
Ok thanks Marc
Have a great weekend 😀
wesacosa
(Donor 2021)
x 3
Unread post by wesacosa »
Hi. Looking for the part number for the 3 bolts which hold the doseur valve bracket to the bulkhead on a series 2 RHD XM please
Cheers
x 6953
Let me know the item numbers:
wesacosa
(Donor 2021)
x 3
Hi , thanks for that. But it was the ones which attach the bracket with the actuation arm to the bulkhead (3x Internal torx bolts with washers) not the ones for the valve itself. Sorry if I wasn't clear in my first post
