Citroen C4 Picasso (B78) 2014 - Head Unit configuration file
This section is for General Enquiries or for Systems not Covered Above
danlat1415
x 24
Unread post by danlat1415 »
I have a 2014 Citroen C4 Picasso (B78)
VIN - VF7**************[VIN obfuscated, can be read by forum staff]
I updated the SMEG+ head unit system to firmware version 5.43.A.R2 a couple of years ago, and I know that it's meant to be connected to Diagbox by a dealer to have the configuration file updated (via a live connected version of Diagbox)
(I heard it has something to do with Bluetooth, but I don't know).
This is now the only fault remaining on my Diagbox scan - and I was hoping to finally get this fixed/removed.
I try clearing the code but it remains.
Is there any way to permanently remove the fault, or to fix the configuration file that it seems to be requesting?
x 1938
Re: Citroen C4 Picasso (B78) 2014 - Head Unit configuration file
I don't know what error you have or what code it is throwing up but a configuration file requirement should not throw up an error code. It's similar to setting your new TV to minimise the synchronisation delay between vision and sound. It's a configuration change, not an error.
Mirascripts my be able to change the Bluetooth delay but I have no information on how to do this.
x 6956
We'd need the actual fault code to determine what the issue is. Pop up the fault from Diagbox.
danlat1415
x 24
I get 2 different error codes relating to it;
Instrument Panel;
State of ECU - CIROCCO
Reference 1: 9806552180
Faults present: 1
B1003 : Fault: secure configuration faulty
Characterisation: Absence of configuration
Status: present
Variables associated with the fault
Telematic unit (RTx) or audio-navigation
State of ECU - ECU not recognised
Reference 1:
Faults present: 1
F300 : calibration file downloading fault
Characterisation: not characterised
Status:
x 6956
Ok, so these are both configuration faults of the telematics unit and it needs a dealer configuration in connected mode to either check the configuration or to apply a calibration file. It's basically locked in secure mode which means you can't do it yourself as it needs connected access.
danlat1415
x 24
I thought that was the case, but I wanted to check.
It's not causing any issues with the system or the vehicle, so I'll leave it until it needs to go to a dealer (hopefully never).
