XM Y3 Rear Suspension Cylinder Roll Pin
Assich
Unread post by Assich »
I have one missing from the left rear cylinder and one about to rust through on the right rear. I was hoping someone would be able to tell me their size. Also does anyone refurb the cylinders?
1992 2.0i 8v Citroen XM Prestige Auto
2006 3.0i Citroen C5 Exclusive Auto
aerodynamica
x 216
Re: XM Y3 Rear Suspension Cylinder Roll Pin
Unread post by aerodynamica »
What pin is it? Do you mean the R - clip that locates the suspension push rod in the trailing arm end? Or the clamp that goes around the cylinder to hold the rubber gaiter?
I think you can get the gaiter clip new from various suppliers. Not sure about the R clip though.
Graeme M
Assich
It's the pin that sits in the side of the hydraulic cylinder. I managed to replace it with a 8mm dia. x 32mm long x 2.5mm thick spring pin but I suspect the original was 1.5mm thick.
